Results 1 to 6 of 6
Thread: What cam sprocket needed for E38/E67 etc PCMs LS swap
    Baltimore, Md
    1,213
    The guy has either a 2007 Escalade PCM or a GMPP LS3 crate engine PCM he can use, and my brain is farting right now. They all need 4x cam sprocket, or if you select no variable cam in the drop down can you use a 1x (half moon raised) cam sprocket?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    5BA8
    3,604
    All GEN4s (except E40) take 4x/58x. Only 1x cam gears for GEN3 and E40s.
    email=[email protected]
    2,981
    4x cam sprocket.. Late C6 Z06's cam sprocket are the go to normally (3 bolt)
    Tuner at PCMofnc.com
    Baltimore, Md
    1,213
    Thats what I thought. Wanted to make sure, its the funky TBSS 6.0s and such that use 58x crank and 1x cam (E40s)
    8,037
    No, the '05-06 Trailblazers both 5.3 & 6.0 were 24x/1x, they just have the Gen 4 block/knock sensors/conrods/intake manifold/etc., 2006 car LS2s were 58x/4x. GM never mixed 24x/4x or 58x/1x though there are some standalones that will let you do those mismatch combos.
    Now go find me a 1x single bolt cam sprocket.
    2,981
    Quote Originally Posted by GrannySShifting View Post
    no they don't.. e40 tbss use 24x 1x cam.. E67 use 58x 4x
