Results 1 to 12 of 12
Thread: 92mm Throttle Body IAC Rough idle under load
    Aug 2021
    21
    this is a stock 5.3L with headers LS4 Intake manifold and 12580681 injectors with 92mm Throttle Body DBC. Car doesn't idle normal and IAC doesn't seem to be operating normal specially under load. I'm thinking about drilling the butterfly to see if it help but don't now if I'm missing something else, any help would be appreciated.
    Banned
    Mar 2022
    Indiana
    4,289
    If you drill out the blade the problem will get worse.
    Fix the injector data
    https://forum.hptuners.com/showthrea...l=1#post766924
    Aug 2021
    21
    Should have said make it a little bigger since it has a small whole about 5/62 in it already.
    Aug 2021
    21
    the IAC stays at 00 when at idle in park or neutral but the moment I go into gear it struggles and eventually dies, I can hear the IAC through the intake when it opens (loud whistle) but it seems to not be operating normal.
    Banned
    Mar 2022
    Indiana
    4,289
    You should tune VE. For that you need working O2 sensors and correct data (first tab in excel sheet I linked).
    Aug 2021
    21
    I have update the data and will change O2 sensors tomorrow to see how it runs. Will update tomorrow,
    5BA8
    5,488
    Get rid of 75% of your pids.
    Your throttle blade it too far open, or you have an air leak, the IAC is going to zero. Drilling the hole bigger makes no sense.
    The narrowbands aren't working. You need to fix that.
    The injector data being off is just the beginning. You got a bunch of wrongness going on.
    email=[email protected]
    Aug 2021
    21
    I believe I have corrected the O2 sensors damn harness was pinned wrong I also update the Injector data from Sheet #1 but trims and IAC still the same, here is the latest log and tune.
    Aug 2021
    21
    Here is a log from a 20 minute drive street and freeway, We are going to change the Throttle body back to stock DBC since it seems these 92mm ones give too much problems, Everything in the engine is pretty much stock with a just a few changes. engine is stock 5.3 LM7 with an LS4 intake manifold and injectors and as of now with a 92mm throttle body. we are looking at running as close as possible to a stock tune since car is a Sunday driver with little freeway action.
    Any suggestions on changes I should make would be greatly appreciated. Thanks.
    Tuning Addict
    10,887
    Why is it so lean? What's the fuel pressure?
    edit:
    Trouble Codes:
    P0122 - Throttle/Pedal Position Sensor A Circuit Low (Pending, Current)
    Sep 2011
    Portland, OR
    523
    The prob I found with the cheap 92mm is that even with the adjust screw backed out all the way, the blade isn?t fully closed. Nor is it centered in the housing worth a shit.
    I used a dremel to grind the pad where the screw hits the body until the blade would stick closed. Then loosen the blade screws to let it self center.
    Readjust the screw to get it just past the stick closed point, and you will now have tuning room.
    Reset the TPS and IAC and it should now have IAC range.
    Sep 2016
    Richmond Texas, for now
    6
    I had a similar problem and once I found the following write up and opened up the IAC port it helped a lot. https://forum.hptuners.com/showthrea...C-in-92mm-Fast
