Can i somehow look at a " stocktune " without connecting a interface in vcm suite?
I kind of want to see what i can edit at my Golf Gti-18 before buying a device.
all you need is a stock tune file and the latest version of the suite
post in the audi section.... you will have better luck getting the file there
thanks.
i got a file to an s3 2020. When ever i try to open a file that isnt already in the editor catalog it just says please connect a interface
no, you won't be able to without an interface. That interface doesn't need to be tied to your car or account or anything like that, so if you can borrow one, that would work also.
Most newer applications require an MPVI2 or newer device to be connected to view the files since they are server based definitions. Some new new vehicles require MPVI3.
Its limited to what we map out. For instance most ecm's have upwards of 10,000 tables in them. We don't believe you need access to all of them as many are actually not even used or just not something you'd want to ever modify. So we add what is necessary to tune your vehicle. Usually 100-2000 tables depending on the application.
Ok, lets put is this way then.
What do i need and what will it cost me to : Make changes to my already tuned Golf Gti Dsg -2018.
I`m not happy whit the ( not shore of the name ) pedalmap. This drives me crazy
Later i want to : Get it to run flexfuel ( is this possible?)
Fit:
Highpressure pump
Lowpressure pump ( if needed )
Is38 or garrett powermax st1
MPVI3 & credits will get you started. You can determine how many credits are needed for your application on our supported vehicle list.
