Results 1 to 20 of 23
Thread: electric fan clutch on P59?
    Aug 2024
    Georgia
    9
    Having issues with clutch fans. Either not loaded engine running at 183 or loaded at 26,000lbs and running at 210 with rear axle at 230. would like to install the electric clutch fan that they use in the trailblazers on my P59 in my Expresss 3500. I've seen that the P59 seems to only have the 2 fan option but there seems to be a pwn drop down. Has anyone tried this successfully?
    03 Express 3500 60,4L80,Liquid cooled Dana70hd 5.13 gears, 8.1 radiator,255 amp alternator, 10,000 watt inverter, 2 air compressors
    Sep 2021
    Kentucky
    1,839
    Post your file.
    North Carolina
    4,829
    Those EV PWM fan clutches are notoriously terrible.. Just a FYI.
    I sell a ton of electric fan kits because how often they fail in trailblazers.
    405
    3,214
    This. We has a 02 Trailblazer with the 4.2L and that fan was one of the worst things about the whole vehicle.
    SoCal
    1,851
    Those fan clutches had the second most Engineering software corrections of any GM vehicle I have worked on. Only surpassed by Dmax's.
    Aug 2024
    Georgia
    9
    advise
    So what do you suggest? I need something that is adjustable. Prefer something that i can either control from the P59 of a controller on the dash. They used these even on the Kodiak trucks but those were bigger clutches on the 8.1 engines.
    Aug 2024
    Georgia
    9
    What do you suggest for towing? Fully loaded at 12 tons i need more cooling than electric fans will likely offer. I was also thinking about the bigger clutch they use on the Kodiaks with the 8.1.
    North Carolina
    4,829
    Yeah I would do some sort of clutch fan
    2,747
    Are the temps highway temps or in traffic temps?
    Aug 2024
    Georgia
    9
    Both I was delivering a box truck 2 days ago, sat about an hour with ac running while unloading truck and waiting on a check. IAC was 207, engine 240 and trans 232.. That rarely happens. Usually just have an issue at full throttle on interstate running 77 mph pulling my 5,000lb 40 foot trailer with 8,500 lb box truck, bus, or motorhome on trailer. Usually i get 5mpg towing these trucks.
    2,747
    Sounds like you might need more radiator than you need more air movement. Plus, an additional/larger trans cooler
    Aug 2024
    Georgia
    9
    im using the 8.1 radiator that is twice as thick as the radiator for the 6.0. when i start having issues i replace the fan clutch and problems go away. unfortunately, im able to replace the fan clutch in 10 minutes now because i replace so often.
    2,747
    Did you ensure that the air coming through the grill can't bypass the radiator?
    Sep 2021
    Kentucky
    1,839
    Have you cleaned the ac condensor?
    Aug 2024
    Georgia
    9
    Im picky on cooling so i often clean the trans cooler, ac condenser and whenever i remove the shroud to replace the fan clutch i also inspect the front of radiator. Advance auto parts fan clutch is either engaged causing lots of noise and choking the engine of power or doing nothing at all. Oreily auto parts fan clutch was slow to kick on but once it did it also choked the engine. Autozone seems better, most of the time does just what i need, gives good power, good cooling, and not as noisy. but when it comes to the 98 degree temps in florida while im towing almost to the limit it struggles. Both Oreillys and Advance auto parts clutches took so much power that at times i couldn't get over 65 mph nor pass up a gas station. Autozone clutch allows me to maintain 75-80 mph loaded and get 5.5 mpg. the only option i was thinking is a pwm electric clutch that i can control with the P59 or an aftermarket fan controller that i mount to my dash. last option is to swap the 6.0 for an 8.1. but in theory i will still have the same issue if the fan clutch is wasteful then it will be noisy and even worse on fuel economy.
    Sep 2021
    Kentucky
    1,839
    How about a standard 2500 truck fan with a aux blower fan on the condenser? Have you tried changing the waterpump or thermostat? May need to run some flush through the engine passages.
    Sep 2021
    Kentucky
    1,839
    Im not a fan of lower temp thermostats but a 160 should get rid of 10-15* and have the clutch fan coming on earlier and with less lockup. If the heating is going on at lower speeds the aux fan on condenser should be a nice upgrade.
    SoCal
    1,851
    May want to go with an nice high flow pusher fan in front of the condenser with a temp switch/sensor that goes in the upper hose or TStat housing.
    Aug 2024
    Georgia
    9
    according to autozone, the fan clutch im using is the same as they sell for these vehicles.Astro 2WD (10)
    Astro AWD (10)
    Avalanche 1500 2WD (7)
    Avalanche 1500 4WD (7)
    Avalanche 2500 2WD (2)
    Avalanche 2500 4WD (5)
    Blazer 2WD (10)
    Blazer 4WD (10)
    C1500 1/2 ton P/U 2WD (11)
    C1500 1/2 ton Suburban 2WD (4)
    C1500 Suburban 2WD (1)
    C2500 3/4 ton P/U 2WD (8)
    C2500 3/4 ton Suburban 2WD (4)
    C2500 Suburban 2WD (1)
    C2500HD 3/4 ton P/U 2WD (9)
    C3500 1 ton P/U 2WD (8)
    C3500HD 1 ton P/U 2WD (2)
    Express 1 ton Van (9)
    Express 1/2 ton Van (15)
    Express 1500 2WD (10)
    Express 1500 AWD (7)
    Express 1500 LS 2WD (5)
    Express 1500 LS AWD (5)
    Express 1500 LT 2WD (5)
    Express 1500 LT AWD (5)
    Express 1500 Van 2WD (17)
    Express 1500 Van AWD (10)
    Express 2500 2WD (35)
    Express 2500 LS 2WD (30)
    Express 2500 LT 2WD (29)
    Express 2500 Van 2WD (17)
    Express 2500 Van AWD (1)
    Express 2500HD Van 2WD (6)
    Express 3/4 ton Van (17)
    Express 3500 2WD (38)
    Express 3500 LS 2WD (29)
    Express 3500 LT 2WD (29)
    Express 3500 Van 2WD (17)
    Express 4500 2WD (1)
    G10 1/2 ton Van (25)
    G1500 1/2 ton Van (6)
    G20 3/4 ton Van (26)
    G2500 3/4 ton Van (6)
    G30 1 ton Van (22)
    G30HD 1 ton Van (6)
    G3500 1 ton Van (2)
    G3500HD 1 ton Van (2)
    K1500 1/2 ton P/U 4WD (11)
    K1500 1/2 ton Suburban 4WD (4)
    K1500 Suburban 4WD (1)
    K2500 3/4 ton P/U 4WD (6)
    K2500 3/4 ton Suburban 4WD (4)
    K2500 Suburban 4WD (1)
    K2500HD 3/4 ton P/U 4WD (6)
    K3500 1 ton P/U 4WD (5)
    P30 (4)
    S10 P/U 2WD (12)
    S10 P/U 4WD (13)
    Silverado 1500 2WD (36)
    Silverado 1500 4WD (35)
    Silverado 1500 AWD (3)
    Silverado 1500 Classic 2WD (6)
    Silverado 1500 Classic 4WD (6)
    Silverado 1500HD 2WD (5)
    Silverado 1500HD 4WD (5)
    Silverado 1500HD Classic 2WD (1)
    Silverado 1500HD Classic 4WD (1)
    Silverado 2500 2WD (8)
    Silverado 2500 4WD (8)
    Silverado 2500HD 2WD (22)
    Silverado 2500HD 4WD (22)
    Silverado 2500HD Classic 2WD (2)
    Silverado 2500HD Classic 4WD (2)
    Silverado 2500HD LT 2WD (2)
    Silverado 2500HD LT 4WD (2)
    Silverado 2500HD LTZ 2WD (2)
    Silverado 2500HD LTZ 4WD (2)
    Silverado 2500HD WT 2WD (2)
    Silverado 2500HD WT 4WD (2)
    Silverado 3500 2WD (14)
    Silverado 3500 4WD (14)
    Silverado 3500 Classic 2WD (2)
    Silverado 3500 Classic 4WD (2)
    Silverado 3500HD 2WD (3)
    Silverado 3500HD 4WD (3)
    Silverado 3500HD LT 2WD (2)
    Silverado 3500HD LT 4WD (2)
    Silverado 3500HD LTZ 2WD (2)
    Silverado 3500HD LTZ 4WD (2)
    Silverado 3500HD WT 2WD (2)
    Silverado 3500HD WT 4WD (2)
    Suburban 1500 2WD (11)
    Suburban 1500 4WD (12)
    Suburban 2500 2WD (15)
    Suburban 2500 4WD (15)
    Suburban 2500 LS 2WD (4)
    Suburban 2500 LS 4WD (4)
    Suburban 2500 LT 2WD (4)
    Suburban 2500 LT 4WD (4)
    Tahoe 2WD (24)
    Tahoe 4WD (23)
    Sep 2021
    Kentucky
    1,839
    Thats what i was thinking. It seems like the 1500 fan shrouds are much smaller to match the smaller radiator. Would the 1500 and 2500 have different fans to bolt onto the same clutch? I still think a blower fan on the condensor would be a good idea, probably a standard toggle switch to a relay would be fine and only use it at lower speeds or high loads.
