Results 1 to 13 of 13
Thread: LTFT running rich
    Potential Tuner Rano90's Avatar
    Sep 2024
    Dubai
    7
    LTFT running rich
    I just got my MPVI and started a log on my 2014 Yukon Denali. I noticed it was running rich most of the time LTFT reaching -17.
    I added my log here..can anyone advise me what I need to be looking at first?
    is it bad O2 sensors or should I go ahead and do a MAS re-calibration.
    Appreciate the support.
    the car is in stock form fully, except for a muffler delete.
    GMC-YukonDenali2014 - Cruise After base tune2.hpl
    and this is the current tune on the car
    GMC-YukonDenali2014 - Tourque Converter Slip.hpt
    And here is the first log I took at stock ECU tune
    GMC-YukonDenali2014 - Base Drive.hpl
    5BA8
    5,491
    What's done to the vehicle? Or are we playing a guessing game?
    email=[email protected]
    Sep 2024
    Dubai
    7
    North Carolina
    4,879
    Looks Ok to me.. Even stock cars aren't 0/0.
    Tune away.. Specifically the MAF table would be a good start.
    Sep 2024
    Dubai
    7
    So I shouldn't be worried about the -17 values? I got these even after resetting the LTFTs.
    Thanks for the reply.
    405
    3,234
    Is it Flex Fuel?
    5BA8
    5,491
    It's better running in the negatives than positive. If it were adding fuel that would be a sign of lower fuel pressure.
    Being off 17% is nothing to worry about. It has to be off a lot more than that before the PCM thinks somethings wrong.
    Sep 2024
    Dubai
    7
    Is it Flex Fuel?
    No, gasoline
    Tuning Addict
    10,887
    By not posting the tune file you're forcing people to ask things, and those are things you may not fully understand, and so the questions have to be asked multiple times before the real information gets transmitted. But if you post the tune file, we can open it and see if Virtual Flex is still enabled, and then tell you to turn that off and never turn it on again.
    Sep 2024
    Dubai
    7
    Thank you for the response...It's my first time here, appreciate it. This is the current tune on the car.
    Sep 2024
    Dubai
    7
    Thank you so much, appreciate the advice.
    Tuning Addict
    10,887
    Stock except muffler delete and DOD disabled and idle speed adjusted and virtual flex turned off and lots of transmission changes and also some other stuff, is different from a flat statement of 'stock except muffler delete'.
    Sep 2024
    Dubai
    7
    Apologies for that, I thought these should not be affecting fueling, As I've seen LTFTs at -17 even with the first drive log I took with stock ECU tune. I'm attaching that log hereGMC-YukonDenali2014 - Base Drive.hpl
