Originally Posted by
ChuckieD
DodgeBoy_8HP,
Thanks for taking a look.
We see the same thing.
I was using the timescale that started at 07:28:03.763, from when data logger was powered up, not 0:0:0.000 from when logging was initiated.
Yes, spark drops to 15 ATDC when I get out of it.
It was running at 14 BTDC as I explained above.
ESP trips a second after speed flattens.
Traction control is off.
It didn't trip when I spun in 5th.
There is just a small amount of rpm bobble showing.
The car and the wheels were pointed in the right direction and takeoff speed is closer to 350 MPH for this pig.
Why does ESP trip?
The shift RPM is 6700.
Shift was commanded at 6749 RPM.
Flare to 6757 RPM is not excessive esp with the dynamic nature of things at the time.
The trans output shaft is following the engine RPM excursion.
Amazing that it shifts in .5 second from command to declaring engagement, and half of that time is thinking vs shifting.
With transmission torque management enabled, the only way to go.
Anyway, still looking for the smoking gun.
Regards,
Chuck
