Results 1 to 20 of 34
Thread: need calibration checkup on newly acquired gen5 camaro 1Le built cammed ls3 E85 tune
    Nov 2022
    15
    just picked up this camaro. hoping someone could look through this calibration file and make sure its a quality tune. camaro_asfound1.hpt
    thank you in advance for your time
    2,788
    Quote Originally Posted by Millspecauto View Post
    Need to add a log also for review. The tune may tell you how it SHOULD run, but a log will tell you how it IS running.
    Nov 2022
    15
    car doesnt have a wideband yet. can it be checked over for anything that is obviously not as it should be? i can post a log but it wont have afr just o2s
    Nov 2022
    15
    for instance. i see enrichment ramp in set at 2.0000. that seems excessive...
    2,788
    You can still tell a lot without wideband, just not everything.
    Sep 2021
    Kentucky
    1,848
    It doesnt matter if its 1 or 4 on a na build.
    Sep 2021
    Kentucky
    1,848
    For starters i would add .1 to the enrichment ramp out rate. That is way too much spark advance from 3400+ at wot. A load bearing dyno would never agree. I just picked up 13hp in a cammed ls3 going from 28-29* advance to 21-23 with it ramping to 25* toward the very top. The car was on 93 octane but you still should not run that much advance.
    Tuning Addict
    10,887
    That's 130* water on an engine dyno timing.
    Sep 2021
    Kentucky
    1,848
    You can try this. Much more realistic.
    Sep 2021
    Kentucky
    1,848
    I still dont see it liking 28* at peak torque even in those conditions.
    Nov 2022
    15
    Funny you bring this up. The car has an electric waterpump. No thermostat or heater or ac. And cooling system appears to be running water/water wetter. No antifreeze. Takes a while just to hit 150-160 at cold start. Would this have anything to do with the timing being the way it is?
    Tuning Addict
    10,887
    Well that's not good for it long-term.
    Sep 2021
    Kentucky
    1,848
    Im curious why there is no flex sensor?
    Nov 2022
    15
    I just got the car. Previous owner had little information. I can see that it?s running virtual sensor.
    Tuning Addict
    10,887
    No it's not, flex is disabled. 'Flex' means it adjusts based on alcohol %, this one is just tuned as if it will only ever have 85% ethanol in it and hope for the best.
    Unless you're planning to use it as a trailered race car, this needs some mechanical sorting out (real water pump, real thermostat, E sensor, etc) and then tuned by somebody who knows what they are doing.
    Sep 2021
    Kentucky
    1,848
    The winter blend of e coming up is going to make it pretty fat.
    Nov 2022
    15
    I live in south Texas, we don?t get winter blend. It?s always basically the same. And I?ve already sorted out the coolant temp issue by changing fan percentage.
    5BA8
    5,474
    I'd put a thermostat in it. All LS engines make more power and run better at 200 degrees than they do at 180.
    email=[email protected]
    Sep 2021
    Kentucky
    1,848
    My experience on the dyno, the cooler i can keep the ect the more power i make. Hotter oil makes more power. I would recommend a thermostat just for the purpose of keeping the temps stable and controlled. A 160* stat will make more power than the stock 187ish*, you will have reduced oil life and more sludge/buildup with the cooler stat unless you can run the dog piss out of the car and keep the oil hot.
    5BA8
    5,474
    My experience is the exact opposite. Only exception is the factory blower cars that like to run just slightly cooler than the NA motors.
    Had one recently that was drastically different hotter than cooler. Buddy had just finished putting together an E85 combo (turbo), almost solid block, very small cooling system drag radial car. We started out trying to make pulls starting around 140-150 degrees knowing it would heat up quickly. The thing sounded and felt like a turd at that temp. Then after one pull I did another right after, with the starting temp over 180* and it made nearly 100 hp more and felt and sounded much cleaner. This was on a chassis dyno.
    Oil temp makes a difference also, obviously, but higher coolant temps consistently make more power with these motors.
