Results 1 to 20 of 30
Thread: Gen 3 5.3 TUNING HELP LOOKOVER TUNE SLOW DOWN LOW
    May 2022
    11
    Exclamation Gen 3 5.3 TUNING HELP LOOKOVER TUNE SLOW DOWN LOW
    [attach]154043 5.3 standard bore
    1. 5.3 standard bore
    2. summit level 1 cam 209/217 112
    3. 317 heads
    4. ls 7 lifters
    5. btr pushrods
    6. summit pro flat top pistons
    7. aus 42pd injectors
    2,762
    Need log also.
    Did you get full GM data with those injectors?
    Advanced Tuner abc's Avatar
    Jan 2024
    943
    Yep, need the .HPL file of the concern area and more description. Keep in mind, as long as the fueling is close, the ignition timing makes the biggest impact on power production of a finished combo.
    North Carolina
    4,831
    A log would be helpful
    Jan 2024
    943
    You need to address your ignition table/tables. 1 degree of advance at 1500 rpm would be my guess at explaining your original concern.
    May 2022
    11
    i have added two to the whole high octane table an low an still feels sluggish
    2,762
    How come people never want to answer questions about their injector data?
    May 2022
    11
    yes i got the injector data with the injectors i ordered them from lsx celebration part number 56010-380-8-D
    2,762
    Unless you are 100% sure on how you entered the injector data, you should post it here so it can be confirmed. Very few people get it right.
    Jan 2024
    943
    Quote Originally Posted by JunkyardDog View Post
    These guys are gonna need to verify your injector data. I have not studied that part of it very much, I just buy known high quality in that area that is known to come with correct data. Once that is done, learn how to look at your log and cross reference the proper tables, in this exercise, it's the spark tables. If you scroll through your log, you will see when you attempt to accelerate, at 50 percent throttle angle, 90 kpa MAP, and 1500 rpm, the PCM is calling for 1 degree of ignition advance. Adding 2 degrees to that is not gonna be much help. Just a guess but, your gonna need to be somewhere around 15 degrees at that point for some sort of decent power production.
    May 2022
    11
    Injector data for 42lb injector
    I can?t find the card that came with them here is what I found on ausinjector website
    Tuning Addict
    10,887
    I don't see whatever you were trying to post or link to or whatever, but that company sells 'modified' injectors (redrilled), and they do not have any real GM-format data, which is the same as not having any data at all.
    May 2022
    11
    how would i get the gm format data
    Tuning Addict
    10,887
    You could send them off to somebody who has the lab testing setup, or just buy injectors that come with data meant for use with the GM ECM/PCM. I wouldn't spend money for the characterization service for only one single set of questionably-modified scam injectors.
    Tuning Addict
    10,887
    https://www.ebay.com/itm/27442490602...n=90000million
    (yes, I am quite fed up with ebay's tracking data they add onto all their links, so I made up some of my own)
    Banned
    Mar 2022
    Indiana
    4,289
    You didn't see this from their site? Flow rate is correct for 4bar GM pressure. I checked the math. That implies the data is valid for GM.
    May 2022
    11
    I attached the card earlier today I believe it’s a timing issue
    Banned
    Mar 2022
    Indiana
    4,289
    All I see is a vehicle that hasn't been tuned. What even is the problem statement?
    Dec 2019
    MS
    1,207
    The IAT Spark was subtracing 7* on that datalog So you had a total of mid teens on timing at WOT.
    Plus down low rpm under 2000 it was very low on timing as well.
