Originally Posted by
blindsquirrel
It can also go 'inline' with any of the other modules, all the CAN+ pins are the same as any other, all the CAN- pins are the same. Wiring it up as DLC -> TCM -> FPCM -> ECM (which has in internal resistor, and only one pair of CAN pins) would be the cleanest diagram-wise. The exception would be if the FPCM is located way off somewhere all by itself and putting the terminating resistor there would avoid having to run another pair of wires back to where the other modules are.
