Results 1 to 10 of 10
Thread: tbss 6.2 swap
    Sep 2023
    Bay Area, CA
    62
    tbss 6.2 swap
    Using an e67 (2009 tbss 6.0 OS), what tables should I copy over when doing a 6.2 swap? boosted application, I am referencing a ctsv file. Running good as is currently, creating a new file for when the 376 goes in.
    How many/what tables are important to copy over? all of the open loop stuff? all of the torque coefficients? cylinder charge temperature bias/filter? zone boundaries? max brake torque?
    Is there a faster way than having the ctsv open in compare and manually copying and pasting in? my current file and the stock ctsv file is attatched.
    7275 id1050 TT3 mafscreen3 BC7 tutd startupidle boundary1 IVTGstock.hpt
    stock ctsv.hpt
    Sep 2023
    Bay Area, CA
    62
    bump
    2,805
    In general you don't try to copy another file over, you tune your current file. Except for the basics of map settings, injector changes etc.
    North Carolina
    4,874
    I do not recommend copying over from another stock file.
    Advanced Tuner biholliday's Avatar
    Nov 2020
    Kingman AZ
    211
    why not just boost your 6.0?
    Sep 2023
    Bay Area, CA
    62
    it is boosted, technically a 5.3 currently. swapping in a 376 for more low speed power. the 5.3 wont die though lol
    Sep 2023
    Bay Area, CA
    62
    also looking for remote tuner recommendations who is extremely affluent with boosted tbss stuff
    Advanced Tuner abc's Avatar
    Jan 2024
    958
    Quote Originally Posted by poulina View Post
    There is a reason the manufacturers try to stay under square with the bore and stroke! Need more bottom end, add more boost sooner.
    Tuning Addict
    10,887
    Also rod ratio! (psst: low speed torque is neither of those things)
    Sep 2023
    Bay Area, CA
    62
    the larger displacement should get the charger moving at a lower engine speed, which will provide the "low end grunt" im after. obviously the top end will suffer as the turbo sized for a 5.3 will choke out a 6.2 much earlier? then comes another turbo upgrade lol.
    I also have a 4" stroke ls2 sitting in my garage that needs a home...
