Results 1 to 8 of 8
Thread: Will MPVI3 read VATS status?
    Dec 2024
    10
    I did an LS swap using a 2004 LS6. I had the PCM sent to a tuner who was supposed ot turn off the VATS. I suspect it is not turned off. If I borrow a friends MPVI3 and plug it into my OBD2 port, can it show me if my VATS is disabled or not? I dont want to spend a bunch of money just to verify the VATS status. If its not then I can send it back to the tuner to make sure he turns it off.
    Dec 2024
    Central FL
    If you do not get an answer for using the MPVI3, you can always get an LED test light and probe the security command pin from the ECM and see if its giving security light command.
    28,778
    read the ecm using vcm editor, then you can see if vats & the dtc's related to vats have been disabled. I think there is also a status bit for vats status as well in vcm scanner.
    North Carolina
    4,874
    Quote Originally Posted by Jd21476 View Post
    Have you asked the tuner to double check his files? He should have it on file still.
    I do a lot of these things and I get blamed for this often and sometimes I do make a mistake but often it is something else.. Like IGN not staying hot in crank and RUN or no fuel pressure etc. Bad cam sensors on GEN 4's can look like a vats issue but on a 04 LS6 it will just usually crank every other time.
    Dec 2024
    10
    What tool do I need ot be able to access vcm scanner?
    Dec 2024
    10
    Quote Originally Posted by GatorBait89 View Post
    What pin number is that?
    Tuning Addict
    10,887
    Yeah but see, the problem with generic "well I guess it might work that way" comments like this is, there is no such thing as a dedicated 'security command pin', it's all done over Class2.
    Attachment 156028
    Show us where to put the test light in that diagram.
    Banned
    Jan 2022
    fountain valley
    2,379
    Yeah but see...
    "wise guy, see..."
    purdy sure he just drills a hole in the controller
    hey squirrel, if you or your buddies are looking for ID1300's i know a guy . )
