Results 1 to 18 of 18
Thread: Gear Selector Setting ZF8
    Nov 2023
    25
    Looking through some of my transmission tunes it seems like the "Gear Selector" is generally set to 10. In the one sticky by Steven he has one set to 29 (one of the manual modes).
    Curious if anyone has seen a stock setting other than 10, and if they can share the tune and/or what vehicle it came with.
    Banned
    Jan 2022
    fountain valley
    2,379
    how does your OS utilize [TCM] 30598 ?
    Nov 2023
    25
    How can you tell?
    From what I gather this value defaults to the map (well the highest map in that grouping) used while "Drive" is selected.
    Banned
    Jan 2022
    fountain valley
    2,379
    Quote Originally Posted by bmagnan View Post
    How can you tell?
    From what I gather this value defaults to the map (well the highest map in that grouping) used while ?Drive? is selected.
    you tell that by logging: <channel ParameterID="7" /> shift ID
    where did you gather that? sounds like you do not understand which table is being used as a shift schedule, or why
    seems like you could benefit greatly from some good help : )
    adjusting the zf8 while not fully understanding what you are changing is a recipe for disaster!
    if you dont want to pay for help i suggest you leave that trans alone
    Nov 2023
    25
    Haha. Shift ID is generally 5, with hard decel at 0, and steep hills at 10. Not that complicated. Manual mode would use table 27 that gets remapped to 5... basically in the ram 80% of the tables are remapped to 5 at some point anyways.
    These trannys aren't that complicated once you dig into them. No sense in all the doom and gloom, especially on the forum where people are trying to learn and share.
    Well said bmagnan... some people in here are only for business and not to share knowledge.
    Now, to your question:
    Some applications will mostly default to Shift ID 5 to simplify the tune (specially if there is no other modes available - like sport, track, ... )
    In case you want to do a test, change manual table to value either 27, 28 or 29. Change shift schedule accordingly. Give it a try.
    Nov 2023
    25
    Quote Originally Posted by John_Carter_2 View Post
    Yea that's the goal, I'll do some tests and report back. I know for me when I enable ERS for instance, it calls out table 27, but then gets remapped to 5 (which also makes sense since ERS is a limiter routine and not directly paddle shift). Seems that I should be able to remove the remapping and keep it in table 27 to retain full paddle shifting (auto stick).
    At the same time, seems like it might be nice to change the gear selector map to point to one of the manual shift tables, and just replace the shift points in there with something from another shift ID (like table 5) and you would have a true setting that would be uneffected by aggression, G force, etc. I think there could be benefits to that for some folks. I know another member had said he did something similar as an early way to disable MDS.
    Banned
    Jan 2022
    fountain valley
    2,379
    What??? What is the goal???
    And paddle shifting is not auto stick, sorry
    Dodge refers to paddle shifting as tip tonic
    Auto stick and tip tonic use completely different schedules
    What exactly are you trying to do accomplish by changing the “gear selector” scalar?
    What exactly are you trying to do accomplish by changing the ?gear selector? scalar?
    Isnt Auto Stick Chryslers lingo more or less for manual shifting? Basically same thing as Tip Tronic like other Manufacturers call it. So if Auto Stick isn't for Manual control of the Auto Gearbox via paddles or Shift Stick, what is it?
    Nov 2023
    25
    The initial question was focused around looking for any transmission tunes someone has seen with the gear selector value set to something other than "10", like in the sticky posted by Steven. For instance, his is set to 29, while mine was 10. To me, setting this value to something like 27 would cause the truck to default to one of the manual maps (or more importantly one of the non aggression maps). See below:
    Map 27 and 28 are used for paddles/autostick, so by changing the shift pattern re-mapping you are able to get shift control instead of ERS too. For instance, my default Ram manual mapping is:
    and 27 is remapped to 5... so when the buttons on the steering wheel are pressed, it calls to map 27, then just get's put right back to map 5 (with the addition of needing button presses to limit the upper gear)
    However, other vehicles are set up with the following:
    which can provide a much clearer overall picture of what's happening and the possible modes the transmission can support. For the Ram though, since it is a PNRD selector and not a PNRDM, there is no way we can get into the "M Gate" section... so that's why they have the same value across all 4 columns. In any event, it does provide valuable insights to the subtle differences in the shift modes between "M Gate" and "Tip Tronic"
    By changing the re-mapping function in my vehicle we can allow the trans to have an actual upper limit set to prevent shifting unless another press of the + button is registered
    As a note, there are different types of manual shifting. Map 27 is paddle shifting (Tip Tronic) and Map 28 is autostick (M Gate).
    One of the things I hope to also accomplish in this new tune is to display the gear in the cluster, so my plan is to change the "Gear Selector" from 10 to 27 (for instance) and replace the map with the values from Shift ID 5, so it will think it's in manual mode and display the gear on the cluster, while still shifting like a normal transmission without the use of manual shifting. I'm not sure if map 27 is the true one I need to use, or if I should use 28, 29, 40, etc... but I'll report back once I have my solution.
    Banned
    Jan 2022
    fountain valley
    2,379
    Quote Originally Posted by Smxtmpr34 View Post
    No. A challenger is not made by BMW. Mopars lingo for auto stick is 'M-Gate'. That's what it is called when you click the console shifter over to the left and turn it into a ratchet shifter.
    Tip Tronic mode is activated if you pull one of the paddles on the steering wheel and is different than M-Gate (uses different scheduling).
    With Tip Tronic mode activated the trans will shift at redline whether you pull the paddle or not.
    With M-Gate the thing will drive right into the limiter if you do not manually pull the lever (ratchet the shifter) before the rpm hits the engines redline.
    This ^^^ is how it works as delivered. OEM.
    With tuning it can be set up to do whatever you want it to do...
    All you need to know is, 1) what you want it to do, and 2) what to change.
    Part of that is knowing the names.
    Glad i could be of assistance : )
    Banned
    Jan 2022
    fountain valley
    2,379
    trying to change what is being displayed on the cluster by changing the shift point for the transmission...
    good luck with that . )
    Nov 2023
    25
    Other tuners have done it on other platforms (other than HP)… so I know there is a way.
    And for the record I’m not hoping to accomplish it by changing the shift points, I’m hoping that by telling the OS to use a certain map (a manual map) that it will also cause some other parameters/settings in the background to change.
    The transmission OS sends some flag to the cluster to tell it to display the current gear… I just need to find out how to make it kick out that message.
    Banned
    Jan 2022
    fountain valley
    2,379
    i may be mistaken but i am 99% certain you will need to go into the BCM to get to where you want to go
    Nov 2023
    25
    For other platforms I think that may be true, but for Rams equipped with ERS they do not work with setting the BCM. It needs to happen through the transmission tune.
    Dec 2019
    49
    I am using the wrangler-392 tcm os on my ram in order to get trx paddles working properly on a non-trx truck. I think my re-map table was read only and I was not able to change it from 5 to 27 originally, thus the need to use the wrangler-392 tcm os.
    Nov 2023
    25
    Yea, in the new Beta VCM Editor it is changeable now, so I think that should be all that has to be done. If not, I’ll check out that OS too. Thanks for the update!
    The current released version is still read only…
    Quote Originally Posted by mike_ct View Post
    Hey mike can you post up that stock 392 file you used? id like to check it out.
