Results 1 to 8 of 8
Thread: Looking for a MK6 Golf R stock file
    Jan 2025
    I currently have a MK6 golf R on an APR stage 2. Currently went through an upgraded the clutch. Turbo is completely toast. Ended up installing a hybrid. Look to get a stock file to compare. Hoping to get it working 😁
    What is the ECU part number?
    Jun 2018
    UK
    56
    Hi Both - Did you get a base file? I`m after one as well. 2019 GolfR
    Do you know the ECU part number?
    I'm looking the same file, the actual part Number is: 5K0907115M (Manual Transmition)
    Apr 2025
    Finding a stock file for your MK6 Golf R can be challenging due to the variety of ECU versions. Knowing your ECU's part number, such as 5K0907115M for manual transmissions, is essential. Sharing this detail in forums like HP Tuners can help others assist you more effectively.
    block blast adventure
    Tuning Addict
    10,887
    Quote Originally Posted by Noreed View Post
    You're in a desert walking along in the sand when all of a sudden you look down and you see a tortoise, Leon. It's crawling towards you. You reach down and you flip the tortoise over on its back, Leon. The tortoise lays on its back, its belly baking in the hot sun, beating its legs trying to turn itself over, but it can't. Not without your help. But you're not helping. I mean, you're not helping. Why is that, Leon?
    Dec 2024
    Florida
    13
    Quote Originally Posted by Sub8 View Post
    The 2019 golf R reads a read file. So when you read the ecm it will show you your stick settings always.
