Results 21 to 40 of 42
Thread: ARF warning light
    Advanced Tuner abc's Avatar
    Jan 2024
    976
    Quote Originally Posted by Chuck Finley View Post
    Then what is he talking about with the "red alert warning light"?
    I guess we will wait for Bill to respond but, Chuck I know exactly what you want to do, as all the stand alone ECM's I have worked with will allow you to set triggers and change the color of the display when the trigger is satisfied. I have never looked but, also have never stumbled across this feature in a stock ECM as they were never designed with monitoring the data in such a way as we are doing with the likes of HPT. Although HPT's does use the "heat map" appearance in the VE table, that I assume was borrowed from a stand alone aftermarket feature?
    Bill, I assume the Core ECM is capable of such a trigger and output?
    2,870
    Quote Originally Posted by abc View Post
    I think he is wanting to use a gauge setup inside the scanner so not really dependent on a stock ECM.
    28,796
    You can download the software for the Core ECM here https://www.hptuners.com/downloads/ its called VCM Live.
    Tuner Chuck Finley's Avatar
    Nov 2022
    Knoxville TN
    52
    Correct
    Nov 2022
    Knoxville TN
    52
    Perfect! I wanted to do this because its a pain the watch the AFR gauge while doing street pulls, so a warning light turning on when I go lean is much easier to see.
  6. #26
    Banned
    Jan 2022
    fountain valley
    2,379
    how can one watch the laptop while making a pass
    vcm live does not work with a mpvi interface and a oem controller
  7. #27
    Jan 2024
    976
    Are you saying one can use an MPVI from HPT with something other than a factory ECM or that HPT has setup input and output triggers with it's software? How is the gauge display not dependent on a factory PCM?
  8. #28
    Jan 2024
    976
    Forget I mentioned "heat map" or "core ECM", neither of those have anything to do with what you want to do.
  9. #29
    Banned
    Jan 2022
    fountain valley
    2,379
    you had said, "I have never looked but, also have never stumbled across this feature in a stock ECM"
    cuz gauges is in the scanner app on your laptop
  10. #30
    Jan 2024
    976
    ... and they scan something other than a factory PCM?
  11. #31
    Aug 2021
    1,142
    Maybe Bill thought he was talking about Core?? Idk, but clearly states for Core only.
  12. #32
    2,870
    He wants the HPT scanner gauge to flash at a certain reading. I?ve never really used the scanner as a gauge setup. But it?s there.
  13. #33
    28,796
    Quote Originally Posted by LS ROB View Post
    Maybe Bill was responding to abc and quoted abc's post since abc was asking about Core.
  14. #34
    Banned
    Jan 2022
    fountain valley
    2,379
    You may be right about that…
  15. #35
    Potential Tuner HoustonsBirdman's Avatar
    Apr 2024
    Houston
    Yes, the gauge in HPTuners
    Hey Chuck, if im not mistaken you are asking for the gauge within HPT to turn a certain color dependent on whether its lean or rich.
    I opened my gauge layout and settings for my wideband and mine works as you say. If its rich it lights up green, and if it hits the lean threshold it turns the gauge a red color.
    Inside the gauge range properties under the "Scales" tab you can see I have:
    "Range Colors"
    Level 1 - green,
    Level 2 - yellow ,
    Level 3 - red
    Then if you click "Gauges Layout" there are also "Ranges".
    Well I have my:
    level 1 "start and End" at 0 - 1 (1 being 1.0 lambda)
    Then I have my level 2 at 1.01 - 1.20
    And finally level 3 at 1.21 - 2
    When my wideband would go lean the face would light up and somewhat flicker a red color.
    Heres some screenshots of my settings. Hopefully they may help. If not, sorry, just trying to help
    ~ 2001 Suburban LM7 5.3, Low Buck Truck Cam (Richard Holdener), BTR Springs, Upgraded Rockers, Shorty Headers, MBRP Cat-back, CAI, 40k Trans cooler, Corvette servo, E-fan conversion, Lowered 2/4 free travel mod, Tuned by Me!
    ~ She isn't perfect, She isn't "fast" at 7000lbs, and the tune isn't perfect. But shes mine, she drives good, and everything is done and tuned by Me! And thats good enough for Me! Oh, and she looks damn good doing it!
  16. #36
    Jan 2024
    976
    I think you nailed it!
  17. #37
    Banned
    Jan 2022
    fountain valley
    2,379
    IT'S NOT DO ABLE
    never say never : )
  18. #38
    Nov 2022
    Knoxville TN
    52
    Quote Originally Posted by HoustonsBirdman View Post
    "Range Colors"
    Level 1 - green,
    Level 2 - yellow ,
    Level 3 - red
    Well I have my:
    Sorry for the late reply, the flu got me but yes this is exactly what I was looking for. And this is for the MPVI and not CORE correct? And I really appreciate the help.
  19. #39
    Nov 2022
    Knoxville TN
    52
    never say never : )
    The bad thing is that's what support told me.
  20. #40
    Apr 2024
    Houston
    Yes sir, MPVI3 is what Im using. Now I am using their beta software, not sure if that would matter
