Got a new fuel tank, lesson learned don't let project cars sit for years with 2 gallons of gas. Probably could've been fixable with some acid washes and rinses but time is more hard to come by than money, not that I've got stupid money but I sure as hell don't have much time with two kids and running a business.
I think I'm doing this correctly. Scaled my VE table up based on some previous stuff and I think the tune is looking pretty good. STFT are just about all single digits. I just would like for someone to verify I'm in VE and not using the MAF. It looks like the MAF is still being read in on the log, but it does show on the log details the following:
Trouble Codes:
P0103 - Mass or Volume Air Flow A Circuit High (Pending, Current)
Controller Type ID By OS: 512
I know Goat Rope doesn't have the best rep around but I followed his guide on disabling the MAF so if I need to do something different just point me at it.
Only issue I'm having is when coasting to a stop sometimes it wants to stall. I know the cause is probably due to no VSS but the Holley Crossmember with the Dakota Digital VSS Cable pass through are just not playing nice and the tension was causing a bad leak.
Car:
Specs:
LQ4, Stage 3 truck cam, headers, dual 2.5 exhaust in a GM A-Body. 42lb FIC injectors, actually flow 50ish at 58lbs, truck rails and return style regulator. 700r4 transmission, so no tcu components. Stock heads and pistons/compression.
Previous Threads:
https://forum.hptuners.com/showthrea...n-a-cammed-lq4
https://forum.hptuners.com/showthrea...a-cam-swap-lq4
2025-2-7.hpl
2-7-25 no maf.hpt
