looking to build a flex fuel harness. What size pins do we need to pin the ecm? I know it's a square head shape
Common GM size E38 E92 type ecms
I found 12-14 gauge, 16-18 and 20-22. If I had to guess I would think 16-18
Honestly, the easy way is buy a junk harness or connector cores, harvest the pins to be used in other projects.
https://www.ebay.com/itm/264706722819
Lol, that's exactly what I did. I had an old harness laying around and it was sacrificed.....I then found a set of pins I had laying around 5 minutes later![]()
https://www.mouser.com/ProductDetail...oi%2FjMQ%3D%3D
I believe I still have my roll at home. How many do you need?
Are you sure these are the correct dimensions?
Here's a screenshot from a video tutorial; they're not the same.
E38, E40, E67, E92, T42 all have the same round terminals for all locations except the big main ground on the ECMs.
T42:
