Results 1 to 7 of 7
Thread: 2019 Challenger procharged need help for emissions
    Hey everyone,
    I am new to tuning and my previous remote tuner has decided to stop helping me, my 2019 Challenger needs to go through emission and my last data log with him I had 4 check engine codes come up, 3 for injectors and 1 for fuel level sensor B, I swapped out the injectors to go back to the ones that pro-charger included with the kit and I am not sure how to make it so the car runs to be honest, it starts then has a rough idle and shuts off, I had 1000cc injectors in and now they are the ones from Procharger at 39.5lb and I am not sure where to even start, can someone please guide me on what I need to update so I can try to get through emissions? and can I turn off the code for the fuel level sensor B? I upgraded my fuel system to a Fore Innovations dual pump and had to change a few things in the fuel tank for side B and it's giving the code P2066 and the only thing I can find to do to correct it, is either replace the module or the entire ECM according to Google and I really don't want to need to do that.
    Mar 2021
    Pompano Beach FL
    478
    whats the complete build? why did you go with 1000cc injectors? what fuel pump? are you using a BAP? were is the data log and tune file?
    Help us help you.....
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    Quote Originally Posted by N2speed View Post
    Thank you, its a 2019 Dodge Challenger R/T, 5.7L, Procharged and intercooled, BBK long tube headers, Holley Sniper Intake Manifold, Fore Innovations dual fuel pump 450LPH, here is the latest updated file from my previous tuner and my latest data log, I also had my tuner doing an E85 tune for the car which he did but when I needed to go through emissions, I had to switch back to 91 octane but that's why I have the 1000cc FIC injectors, I have since switched back to the injectors provided by ProCharger which they could only tell me are 39.5lb injectors. 93 easy drive HP Tuner 03_23_2025.hpl2019_Ryan_Law_ChallengerRT_8speed_ProCharger_FIC1000_2Bar_hdrs_nocats_93_3-21-25.hpt
    Mar 2021
    Pompano Beach FL
    478
    what makes you thing the injectors are why it wont past emissions? your tune file says no cats are you sure that is not the reason? also you are not recording enough data to get a clear picture. do another data log with these channels
    www.n2speed.com
    [email protected]
    Banned
    Jan 2022
    fountain valley
    2,379
    Hey everyone,
    and my previous remote tuner has decided to stop helping me.
    locked the tune and told ya to kick rocks?
    damn...
    with the 1000cc my previous tuner said he couldn't tune them low enough to run correctly, so I swapped them with the procharger ones, he stopped responding to me so i am trying to see if I can fix it myself and have not been able to get it to even stay running, cats are back on, they are clamp in, the latest codes that came up were injector codes P0203, P0207 and P0208. as far as the channels you sent I have no idea how to even read at that info let alone load it up for a tune update, sorry i am brand new to this
    damn...
    yeah, not sure what happened, just sent him the latest data log and he never responded, but his previous email said that he was having trouble getting the injectors to push that low of an amount of fuel and that I should try to just get the shop to pass me.
