Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Need to program brand new dealer e67 for 07 trailblazer ss
    Tuning Addict
    10,887
    Hang on, Alvin. The 2008 GMT360 TCM OS is 24239927. The 2008 Express TCM is also 24239927. The 2008 Express E38 (12612384) is definitely an 'early' CAN version. How can that same TCM OS work with both an 'early' E38 and a 'late' E67, if the 2008 TBSS is using the late CAN version?
    May 2006
    Seattle, WA
    543
    08 TBSS has the 63lb/hr IFR so it should be considered an "early E67". 09 TBSS has the 127lb/hr IFR.
    The 08 Express and TBSS have the same TCM OS so it's the best candidate to segment swap 80E stuff for a TBSS.
    Think that was the point, but wanted to clarify.
    09 Express and TBSS have the same TCM OS as well 24243356, but have to make a few changes in the 09 ECM to make it work with the 08 truck (starter config IIRC).
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
    Tuning Addict
    10,887
    The issue is, if the 2008 ECM has the '09-up CAN protocol then it can only work with a '09-up T43. If it's like all other 2008s then it has to use a '08-down T43.
    North Carolina
    4,829
    A 06 and 07 TBSS can swap tcms all day long and they will still work just fine. A 08 cannot run on a 06 or 07 tcm. That is all I know.
