Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Logging wideband via serial port adapter
    Advanced Tuner abc's Avatar
    Jan 2024
    953
    I have set up a few of them and they all work very well. By looking at the logs you would never know it's serial to usb converted. For me the trick was a good adapter and of course the correct settings within windows 10 and HPT correct PID. I use the AEM kit without a gauge.
    https://www.amazon.com/Connector-Ada...TMZHZRSW7&th=1
    https://www.amazon.com/Adapter-Chips...1zcF9hdGY&th=1
    I don't remember the exact brand but I'm pretty sure it's the same brand that goat rope is recommending.
    Oct 2019
    4
    Quote Originally Posted by abc View Post
    Hey I got the same exact cables you got and trying to make it work what settings did you use for it
    Jan 2024
    953
    Do you have the instruction manual? Did you make sure the baud rate is correct for your serial port in your lap top PC? If not see page 7 of the AEM instruction manual.
    Jan 2021
    8
    Can I go from MPVI2 to MPVI3?
    My SC3800 (1997) 85 Fiero is already wired for an AEM Wideband using serial USB.
    AFR would read via the meter plus show on the laptop as an extra gauge when everything was hooked up.
    My old MPVI2 is back in the US with my son. I work overseas.
    Will a new MPVI3 with credits replace it directly without having to rewire for the prolink?
    Jan 2024
    953
    That sounds like a question for HPT, I don't know the answer.
  6. #26
    Apr 2022
    40
    Quote Originally Posted by tonn0297 View Post
    Save yourself the trubble, get the prolink cable and log it analog... the serial in VCM scanner is so insanely bad and they refuse to fix it. What can help is disableing other COM ports, like bluetooth and alike, but its very spotty..
    All the really need is a serial device picker with baud and alike, but nope..
    So is this the consensus for this issue? I checked and updated everything on mine and I still have this problem. My setup used to get this issue rarely but now it's gottenso bad I can get my wideband to work at all.
  7. #27
    Sep 2002
    Chicago, IL
    6,411
    Serial based inputs are something we will not be improving. It works for some, but problematic for others.
    CAN based inputs are the recommended path today.
    Serial based inputs were a nice idea to avoid voltage offsets before CAN based inputs became a thing.
    We got this guy Not Sure, ...
  8. #28
    Apr 2022
    40
    Ok so whats the recommended CAN based setup? Where can I find more info on that? Thanks!
    Quote Originally Posted by Keith@HPTuners View Post
  9. #29
    Banned
    Jan 2022
    fountain valley
    2,379
    some like aem cuz they are inexpensive
    i like ballenger
    used to be able to connect thru pro link + but these days CAN based is all they offer
    its a pita if ya ask me - i am fine with the older anolog stuff
    connects right away/every time - sorta a big deal when you are at the front of the staging lanes...
  10. #30
    i like ballenger
    I use the Innovate MTX-L Plus using serial to USB adapter. Worked great for several years. now it will not connect. It shows up in the pid list but goes away as soon as the logging starts. I can however use the Innovate software to log but that's not very convenient. So what are we supposed to do? Spend more money in HP tuners hardware?
  11. #31
    Nov 2018
    Middle TN
    97
    Quote Originally Posted by Speed39 View Post
    On mine I ended up using a small usb hub so that the MPVI and the Serial to usb adapter used the same port on the computer, never had another issue with it not showing up.
  12. #32
    Jan 2024
    953
    That sounds like a cable or port issue. The same thing happens if I forget to plug my WBO2 USB cable in.
  13. #33
    Quote Originally Posted by Pitbull View Post
    I will try that, thanks
  14. #34
    I did try an usb hub today. No luck. I have been able to log the afr with the wideband software however, so my serial to usb must be working just fine.
    This drives me nuts.
  15. #35
    Nov 2018
    Middle TN
    97
    I know I'm asking dumb questions probably, but did you recreate the pid after the installing the hub? And what version of Windows are you using?
    You ain't wrong though, logically you'd think if one software could see it then the other should. But i'm guessing they request info diffrently.
