Hello everyone,
I have an issue with my Turbo Truck, I have been playing with the tune and the tune file for awhile, thought I was chasing a boost leak, maybe still am? Anyways its a 6.0l Gen 3 P59 computer on a 2 Bar OS. I will add my tune file and Scan file. I have modified this so much since switching from a 3 Bar OS to a 2 bar OS. I feel so lost, this is my first boosted car. I had the truck running well last summer before having some heating issues due to cheap China fan's and other inferior products, which i have tried to change over the winter.
My main issue is as I drive the truck around, I get these loud back fire issues, which i believe it from it going lean once the RPM start to climb. I cant seem to build any boost on the engine, which i'm not trying to when the AFR's are low. This seems to be a Fuel delivery / air issue. My boost gauge never seems to go positive so i must have a leak somewhere once positive pressure is introduced.
I have put a smoke machine into the intake, and don't see any smoke until it comes out the turbo filter. Now this isn't pressurized, so some plastic or rubber seal must have failed and is leaking.
At this point, I'm wondering if I'm looking for a failing fuel pump or a failing fuel regulator, or blown out V Band clamp on my inner cooler?
Any advise would be great or where to start. I had the truck running well until my water pump went out last year and i had to modify the whole Fan assembly to put larger fans in. It holds coolant, i haven't done a leak down test, but it doesn't seem to burn it or leave the revisor.
I'm stumped and any advise of how to get this back on the road would be great, thanks in advanced.
The VE Table isn't tuned as I'm having issues running the motor. I understand the premise of changing the VE Table the the AFR data. First turbo motor, not first tuned car.
