Results 1 to 20 of 36
Thread: Btr camshafts
    Sep 2021
    Kentucky
    1,848
    Btr camshafts
    Anyone having luck tuning the btr hemi cams with missing cam specs with vvt?
    Banned
    Jan 2022
    fountain valley
    2,379
    i have
    but i degree the cam with a wheel and an indicator.
    you might wanna check valve to piston clearance while you are in there
    Advanced Tuner Spray-Cam Hell-Ram's Avatar
    Aug 2021
    Yorktown VA
    256
    Absolutely. I believe I have tuned all of their hemi ones. Stages 1 - 4 cams and the Truck Norris cam Ive tuned probably 4 or 5 of those this year. I want to say I have a page in my notepad that has all of the missing cam specs for each as well. I have to look for the page in my notebook but I can recall 2 of the cams missing specs. Hopefully you are using one of these two listed below...
    Truck Norris: 212/230 .587/.586 109.5 +4 adv
    Stage 4 Cam: 224/240 .587/.586 112.5 +3.5 adv
    "1MEAN16" Silver/Black 2016 Ram CCSB (4592lbs) NA 398ci Stroker
    +6cc Mahle Dome Pistons w/ 13.1/1 Compression on E85
    Forged 4.08" Stroke Crank, 224cc AFR Heads w/ Titanium 2.165"/1.65" Valves
    Custom Cam 220/238 .611/.589 108.5 LSA 108.5 ICL, 105mm Hellcat TB
    Ported Hi-Ram Intake, NXpress Hi-Ram NO2 Plate kit w/125 Shot(4 sec)
    Tx Spd 2" Long Tubes, ATI SD 15%UD, Ram TRX K&N CAI
    Dual 450 Pumps, Deatschwerks 1000cc Inj, Fuel Cell in Bed
    Built 8HP70 w/ 3800 stall/Detroit Tru-Trac/410 Gears
    Sep 2021
    Kentucky
    1,848
    More looking at the stage 1 cam potentially for a truck. Thanks for the info. If you have the other 3 cams that would be highly appreciated.
    Aug 2021
    Yorktown VA
    256
    Stage 1: 212 / 220 112 LSA .587 / .586
    Stage 2: 216 / 230 112 LSA .587 / .586
    Stage 3: 220 / 230 112 LSA .587 / .586
    Banned
    Jan 2022
    fountain valley
    2,379
    not sure where you heard those numbers John, but if you check with a wheel, that is not what they actually are.
    doesn't matter
    there are soooo many more duration numbers that need looking at than just the 050 numbers....
    Sep 2021
    Kentucky
    1,848
    I am basically needing enough to setup the vvt tables. They give you a holley table on the card but how many people are using a holley on a cam only charger?
    Edit: i realized they give you just enough info to get going. Full advance on the wot table and subtract from full advance at the different rpm increments according to the chart. Does not necessarily aid with part throttle but i guess the same values can be used? Assuming the cam is lined up perfectly with the crank. That is also the holley way, full advance and retard x amount by rpm. Still a lot of variables and knowing the exhaust centerline would be nice and preferred. Knowing the ecl on the cam does not necessarily equate to what is actually in the engine either.
    Banned
    Jan 2022
    fountain valley
    2,379
    what do you mean?
    Sep 2021
    Kentucky
    1,848
    Machining tolerances and installer error.^
    Banned
    Jan 2022
    fountain valley
    2,379
    understand what effects where the cam can end up
    i do not understand your statement about "centerline vs where the cam actually is"
    centerline IS where the cam actually is
    its where an imaginary line thru the exact center of the lobe is, in relation to the piston for the cylinder that the lobe belongs to
    Sep 2021
    Kentucky
    1,848
    The ecl based on the cam spec or card is not necessarily where it is truly.
    Banned
    Jan 2022
    fountain valley
    2,379
    i think you might be confused...
    any centerline that is printed or specified on a cam card is an instruction...
    its not a number that can be ground into a camshaft.
    Sep 2021
    Kentucky
    1,848
    Not confused. Yes, the cam needs a degree wheel. If the camshaft is at "0" then the icl and ecl are expected to be true to what is printed on the card. No machining tolerance ive ever seen was 0, always has a tolerance big or small. "0" in relation to the crankshaft can be way off or spot on what your cam card says. The lsa is the difference between icl and ecl so the centerlines in fact are ground with a number, assuming its installed correctly.
    Banned
    Jan 2022
    fountain valley
    2,379
    Not confused.
    no, it is not
    Aug 2021
    Yorktown VA
    256
    doesn't matter
    Don, please tell me that you haven't already forgotten?
    Banned
    Jan 2022
    fountain valley
    2,379
    With the fun that you just had with your build you do not have any room to rib anybody…
    about anything.
    Aug 2017
    Quakertown PA
    550
    BTR cams + Audie/Cam Pro Plus = STEP AWAY.
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
    Banned
    Jan 2022
    fountain valley
    2,379
    it looks like there is another bad batch of lifters going around
    i have a customer who had satera do a cam swap last week and at least one of the lifters they got wont pump up
    Sep 2021
    Kentucky
    1,848
    no, it is not
    Ok.
    Banned
    Jan 2022
    fountain valley
    2,379
    the lobe separation angle is ground into the cam, but lobe centerline is not
    "centerline" refers to distance from tdc - and for that you need a crank, a degree wheel, a rod, a piston, a lifter, a dial indicator, and a little bit of math
    those +3.5 +4 advance numbers above are suggestions
    up to the installer to put the cam there, or wherever he likes
