Results 1 to 7 of 7
Thread: GM P01 and P59 Operating Systems for HP Tuners
    Mar 2021
    Yuma. AZ
    130
    This document outlines the operating systems (OSes) for GM P01 and P59 Powertrain Control Modules (PCMs) supported by HP Tuners, including their applications, features, and tuning considerations. The P01 (512 KB) and P59 (1 MB) PCMs are widely used in GM LS-based vehicles from 1999 to 2007, covering cars, trucks, and vans.
    P01 PCM Overview
    Years: 1999?2003 (some 2004 applications)
    Memory: 512 KB
    Connectors: Red/Blue
    Applications: Corvette, Camaro/Firebird, Silverado/Sierra, Express/Savana, 4.3L V6 trucks/vans/SUVs
    Throttle: Primarily Drive-by-Cable (DBC)
    Engines: LS1, LS6, early LS2, 4.3L, 4.8L, 5.3L, 6.0L
    Processor: Motorola/Freescale (upgraded in 2001?2003 "0411" PCMs)
    Features: Supports 1-bar, 2-bar, 3-bar SD; limited Flex Fuel support; injector flow limit 254 lb/hr
    Tuning Notes: Older 1997?2000 P01s prone to damage during flashing; 0411 PCMs more reliable
    P01 Operating Systems
    The following OSes are commonly used with P01 PCMs in HP Tuners. All are 512 KB and incompatible with P59 PCMs.
    12202088
    Applications: 2001?2002 Holden Commodore (Australia), some GM trucks
    Features:
    DBC throttle
    Supports 1-bar and 2-bar SD enhancements
    Basic LS1/LS6 tune, manual/auto transmission
    Tuning Notes: Common in Australian vehicles; superseded by 12208322 for improved tuning
    12208322
    Applications: 2001?2003 Camaro/Firebird, Corvette, trucks
    Features:
    DBC throttle
    Improved over 12202088 with better VE/spark tables
    Supports 1-bar, 2-bar SD; 3-bar with patches
    Tuning Notes: Versatile for performance tuning; good for LS1 swaps
    12212156
    Applications: 2001?2002 Camaro/Firebird, some trucks
    Features:
    DBC throttle
    Supports 1-bar, 2-bar SD; 3-bar with HP Tuners patches
    Electric fan control with A/C and ECT integration
    Tuning Notes: Preferred for swaps due to fan control; ?universal? P01 OS
    12216125
    Applications: 2002 Chevrolet Tahoe (5.3L), other trucks
    Features:
    DBC throttle
    Supports 1-bar, 2-bar, 3-bar SD with boost patches
    Truck-specific idle tuning
    Tuning Notes: Ideal for boosted truck applications; good VE table resolution
    12225074
    Applications: 2003?2004 Holden Commodore (Australia)
    Features:
    DBC throttle
    Enhanced tune over 12202088
    Tuning Notes: Performance-oriented for LS1; used in Australian vehicles
    P01 Tuning Considerations
    OS Swapping: Use HP Tuners ?Write Entire? to flash new P01 OS (e.g., 12212156 for fan control). License the new OS and update VIN/segments.
    3-Bar SD: Requires patches for OSes like 12212156; not natively supported by GM.
    Flex Fuel: Not natively supported; requires significant wiring/OS modifications.
    Bricking Risk: Ensure stable battery; remove radio fuses to avoid voltage drops.
    Upgrades: Use 2001?2003 0411 PCMs for reliability over 1997?2000 P01s.
    P59 PCM Overview
    Years: 2003?2007
    Memory: 1 MB
    Connectors: Green/Blue
    Applications: Corvette, 2004 GTO, Silverado/Sierra, Express/Savana, trucks/SUVs
    Throttle: Drive-by-Cable (DBC) or Drive-by-Wire (DBW)
    Engines: LS1, LS6, LS2, 4.3L, 4.8L, 5.3L, 6.0L
    Processor: Motorola/Freescale (AMD/Intel flash chips)
    Features: Supports DBC/DBW, Flex Fuel, 1-bar/2-bar/3-bar SD; injector flow limit 254 lb/hr
    Tuning Notes: More robust than P01; supports advanced features like E85 and DBW
    The following OSes are commonly used with P59 PCMs in HP Tuners. All are 1 MB and incompatible with P01 PCMs.
    12576106
    Applications: 2003 Chevy Astro, 2003?2004 GM trucks (4.3L, 4.8L, 5.3L, 6.0L)
    Features:
    DBC throttle
    Manual/auto transmission
    Tuning Notes: Simple, reliable for truck/van swaps; good for DBC LS swaps
    12586242
    Applications: 2003?2007 GM trucks/vans (4.8L, 5.3L, 6.0L)
    Features:
    DBC throttle
    Truck-specific idle and fueling
    Tuning Notes: Widely available; ideal for boosted truck applications
    12587603
    Applications: 2003?2005 VZ Holden Commodore, 2004 Pontiac GTO, some trucks
    Features:
    DBC (some variants); DBW (others)
    Flex Fuel (E85) support
    Supports 1-bar, 2-bar, 3-bar SD with high-resolution tables
    Tuning Notes: Preferred for performance builds; verify DBC/DBW compatibility
    12587811
    Applications: 2006 Silverado 2500HD (6.0L), 2005?2007 trucks
    Features:
    DBC throttle
    Truck-specific tuning
    Tuning Notes: Good for heavy-duty truck swaps; supports boost
    12592433
    Applications: 2005 VZ Holden Commodore, some 2004?2005 GM vehicles
    Features:
    DBW throttle (primarily)
    Performance-oriented LS1/LS2 tune
    Tuning Notes: Common in DBW applications; less suitable for DBC swaps
    P59 Tuning Considerations
    OS Swapping: Use HP Tuners ?Write Entire? to flash new P59 OS (e.g., 12587603 for Flex Fuel). License the new OS and update VIN/segments.
    DBC vs. DBW: Confirm throttle type in tune file (?Throttle Control Type? parameter). DBC OSes include 12576106, 12586242; DBW OSes include 12592433.
    Flex Fuel: Supported by 12587603; requires E85 sensor and tune adjustments.
    IAC Chip: DBC setups need P59 PCMs with IAC chip (service numbers: 12575502, 12570558, 12583659, 12589161).
    Bricking Risk: Stable battery critical; remove radio fuses before flashing.
    HP Tuners OS Enhancements
    HP Tuners offers enhancements for both P01 and P59 PCMs, applied via ?Write Entire?:
    1-Bar MAP Speed Density: Naturally aspirated applications
    2-Bar MAP Speed Density: Low/medium boost (turbo/supercharger)
    3-Bar MAP Speed Density: Medium/high boost (e.g., 20 psi)
    1-Bar MAF Enhanced: MAF-based with Real-Time Tuning (RTT)
    Process:
    Open stock tune in HP Tuners
    Select enhancement (e.g., 3-Bar SD) under ?Operating System? menu
    Save as new base tune (e.g., ?Tune_3bar.bin?)
    Flash using ?Write Entire?
    Compatibility: Most P01/P59 OSes support enhancements; some P01 OSes (e.g., 12212156) need patches for 3-bar SD.
    Swapping PCMs and OSes
    Within Same PCM Type:
    P01 to P01 (e.g., 12202088 to 12212156): Flash new OS via HP Tuners; update VIN/segments
    P59 to P59 (e.g., 12592433 to 12587603): Same process; verify DBC/DBW compatibility
    P01 to P59 Swap:
    Requires re-pinning red/blue to green/blue harness
    Adjust wiring for O2 sensors (PCM-grounded on P59), tach, fuel gauge
    Flash P59 OS (e.g., 12576106 for DBC); port P01 calibration
    Key Differences
    Feature
    P01 PCM
    P59 PCM
    Memory
    512 KB
    1 MB
    Connectors
    Red/Blue
    Green/Blue
    Throttle
    DBC
    DBC or DBW
    Flex Fuel
    Limited (wiring mods)
    Native (e.g., 12587603)
    Reliability
    0411 better than 1997?2000
    More robust (2003?2007)
    OS Examples
    12212156, 12216125
    12587603, 12576106
    Recommendations
    P01 PCM:
    Use 12212156 for swaps (fan control) or 12216125 for boosted trucks
    Upgrade to 0411 PCM for reliability
    P59 PCM:
    Use 12587603 for Flex Fuel/boost (DBC/DBW); 12576106 for simple DBC truck swaps
    Verify IAC chip for DBC setups
    Swaps:
    P01 to P59 for modern features (E85, DBW); re-pin harness
    Port calibration tables to new OS
    Safety:
    Backup original bin file
    Stable battery; remove radio fuses before flashing
    Arizona
    1,254
    Thank you for this
    Oct 2004
    663
    That might be handy if it was proofread for errors. 12587603 was NOT a GTO OS. That is just the first glaring thing that popped out to me.
    Advanced Tuner abc's Avatar
    Jan 2024
    939
    The PO1 used in the vetts, started in 97 and is DBW.
    Tuning Addict
    10,887
    Is this some more AI bullshit? The confabulation machine? The statistical average of all the facts (opinions...) that have been fed into the training model?
    28,767
    Quote Originally Posted by abc View Post
    actually the 97-98 vette did not use P01, they used that oddball ecm for those 2 years.
    Sep 2021
    Kentucky
    1,839
    Isnt 12216125 the flex fuel os? No p01 was used until 99 that im aware of.
