Results 1 to 7 of 7
Thread: Torque Management Advance (retard) at 6,000 RPM.
    May 2021
    6
    Hi all. 2018 Camaro SS 6MT (E92) with a BTR 220 cam. Before the cam install the issue was not present. Had the car on a Dynojet for a baseline and the PCM is pulling 10-12 degrees at ~6,000 RPM for Torque Management Advance. Most of the torque tables are maxxed out, torque per gear, etc. Tried taking 5% out of the MAF as an experiment, but the issue was still present. Ideas?
    Tuner lynmup's Avatar
    Dec 2020
    Omaha, NE
    163
    Looking at your logs, I see your virtual torque getting close to your max on your E85 airmass. I increased that portion only 5% to see if it eliminates that spark dip. Lemme know
    Stock Sucks but IT's reliable!
    Dec 2020
    Omaha, NE
    163
    I noticed you are getting a little lean at your upper RPM band (.90 lambda). May want to add a little more fuel to keep it happy. Looks like you still have some left as your injector pw is only hovering around 5ms.
    I updated your E85 Power enrichment to hopefully add the fuel you need. Log and see how it does.
    Dec 2020
    Omaha, NE
    163
    Quote Originally Posted by JANNETTYRACING View Post
    Turn your A/C or defroster off.
    For some reason that is set to 7083 RPM and 200% TPS in the tune, I have mine turn off the A/C when above a certain RPM and pedal position. Its under system - A/C tab.
    Dec 2024
    28
    your Maf looks like might need a rescale at the high end . Its also about 8-12% lean on both the MAF and VVE . Try fixing your airflow model and maybe return all the tq management tables to stock and slightly increase them about 3-5% where needed. Also you are commanding .81 and WB is reading .91
    May 2021
    6
    This was the solution. Thank you! The a/c was setup to never turn off-which was the way the tune was from the factory for some reason. I set it to turn off above 60% throttle and 5250 RPM and the torque management advance was no longer kicking in. I have attached a log. As to the gentlemen who are noting that the vehicle is lean, I think that there is some kind of discrepancy in your channel setup vs mine. I am logging SAE WB EQ ratio and it shows me A/f. The mixture is solid between 12.8 and 13.2 from 2,000 RPM to redline. The gauge in AEM gauge in the car reflects this as well. I appreciate everyone's assistance, this is an awesome community.
