Set-up
2007 5.3L Flex fuel truck motor and all the hardware including DBW
Added turbo
Added injectors #12613412 with non-regulated 58 psi info.
Started with stock tune from 2006 5.3L with 2 bar SD OS
Added 2 bar MAP sensor with change in setting
Disabled MAF
NB O2 bank 1 sensor 1 is installed in the down pipe from a shorty header, 4 to 1.
NB O2 bank 2 sensor 1 is installed in a box that the turbo sits on, a header log if you will.
4 short pipes from bank 2 cylinders and one cross over pipe from the bank 1 side feed this box.
WB O2 is installed in the turbo down pipe or exhaust.
Two log files, one with the cylinder select all set to 1 in an effort to get fuel trims to just look at the right bank?
It appears that my WB conflicts with the NB and the fuel trims.
Can not get it to idle lower than 1000 rpm.
My WB says lean but the fuel trim says way rich.
I am leaning towards leaning out the idle part of the VE table.
I am sure more needs to be done somewhere.
failMAF.hpt
bankselect.hpl
