Page 13 of 14 FirstFirst ... 391011121314 LastLast
Results 241 to 260 of 264
Thread: Injector Data Repository
  1. #241
    Tuning Addict
    10,887
    Short Pulse Adder does not change with fuel pressure/vacuum so if it's already been converted to Gen 3 format then it stays the same. Otherwise, use the old 'LS1 to LS3 injectors.xls' spreadsheet, only for the SPA table. That spreadsheet only works on the early Gen 4 data with 128-640 kPa Delta labels in the Flow Rate & Offset tables, but the SPA format is the same for both early/late Gen 4s.
  2. #242
    Very very appreciated, I'll go and do some practicing
  3. #243
    Looking for 1294512 injector data to put in my 02 P01 ecm. guess i need conversion as well. thanks in advance
  4. #244
    Tuning Addict
    10,887
    If you meant 12594512, then those are already converted and already in my sheet. If you need a one-off conversion for something other than 58 PSI/returnless or 58 PSI/referenced you have to say what you have and then ask for it.
    --->>>>>GM Gen4 injectors converted to Gen3 format for P01-P59 PCMs.xls<<<<<---
    All these are in there, for both fuel system types.
    19421333 - 29lb, various non-flex Gen4 trucks (alt# 12580681)
    12587269 - 33lb, LY6/L76
    12569113 - 33lb, car LS2 (alt# 89017586)
    12594512 - 36lb, LMG/LC9 '07-'09
    12613411 - 38lb, LMG/LC9 '10-up
    12576341 - 42lb, LS3
    12609749 - 50lb, L92/L94
    12613412 - 51lb, L96
    12598646 - 52lb, LSA/LS9
    You're welcome in advance.
  5. #245
    thx appreciate it
  6. #246
    Sep 2018
    Great, thanks!
    anyone having problems finding the data for the various injectors in google sheets, the tabs are across the bottom of your screen
  7. #247
    Jan 2017
    South Carolina
    18
    Green Giant 42lb (50.29lb@4bar) - Bosch 0280155968 - FIC data.
    Under the Short Pulse Correction area, I see two tables, one is obviously the adder , but i'm not sure I understand the other table as it shows Pulsewidth vs ms but in Gen3 P01 PCM its listed as Pulsewidth vs RPM. Does the min inj pulsewidth need to be changed? I see where it says to leave the default injector pulse as stock value so I did. Im asking about the min inj pulse.
    Thanks!
  8. #248
    Tuning Addict
    10,887
    One version is for Gen 3 which has 67 or whatever columns. The other is for everything else (Gen 4) that has the much much smaller SPA table with 33 columns.
    As with every other table in a 'universal' datasheet, use the one that matches the labels/format/shape/size in your tune file.
  9. #249
    Jan 2017
    South Carolina
    18
    Right thank you.
    I don't like to assume but, since I'm using the Green Giant injectors with P01 I assumed the Min Inj PulseWidth data table is supposed to be updated as well based on comparisons to other data to other injector data. It is supposed to be changed correct? If so, what is the data supposed to be? Thanks!
  10. #250
    Tuning Addict
    10,887
    It does say "USE STOCK VALUES FOR SHORT PULSE LIMIT,AND MINIMUM DEFAULT PW". Different ECM families/versions use different terminology for essentially the same tables.
  11. #251
    Jan 2017
    South Carolina
    18
    Yes, and i did leave the stock values which i highlighted in yellow. I have attached a picture of what i'm talking about.Fuel_snip.PNG
  12. #252
    12609749 - 50lb... I've seen else where they are 54lb and I just put them on my deleted camed l77 with flotek ported heads... fuel data? So I can get it close before going to the dyno
  13. #253
    Add for some reason it won't let me open previous posted links you've sent out squirrel
  14. #254
    Tuning Addict
    10,887
  15. #255
    Jun 2024
    5
    Thankyou Blindsquirrel for the good info.
    In your conversion spreadsheet, you have tables for "referenced - vacuum line removed". The data looks like it should be used with the vacuum line connected to the fuel regulator (constant pressure drop acroos the injector). Is the "vacuum line removed" a typo?
    I am building a supercharged LS1 with bosch 0280 158 290 injectors and a 4 bar regulator. Do you have any calibration data for these injectors? (66lb/hr at 3 bar).
  16. #256
    Jun 2024
    5
    Does anybody have a standard .hpt file for an LS9 (corvette or commodore)?
  17. #257
    2,767
    Quote Originally Posted by DBruce View Post
    Probably should be one in the HPT tune repository.
  18. #258
    SoCal
    1,851
    Give me more info. What PCM? Manual? Auto? What year? What OS do you want?
  19. #259
    SoCal
    1,851
    The method he is talking about gives you the max pressure output for the fuel rail. That is important. Everything is "based" on that max regulated pressure.
  20. #260
    Jun 2024
    5
    A manual transmission would be preferred, but anything would do. I am interested in things like acceleration enrichment as well as the base fuel.
