Results 1 to 5 of 5
Thread: Throttle percentage with WOT drops to 55%
    Jun 2016
    Tuscaloosa, Alabama
    82
    e38 ecm throttle percentage is oscillating like it is torque limited. At WOT it shows 100% on pedal but in the log it is going up and down. It is throwing off the fueling and pe during the pull. I have turned off all the torque limiters i know of. have searched for more and found one in the transmission tune. Turned that off and it still cuts it out. What else acts as a limiter for it?
    Also turned off traction control in the tune. yes at the end it goes to 14.3 instead of commanded ratio. will work on that part after I figure out the torque limiting or whatever it is.
    1969 chevelle step 4.0.2 torque stuffs.hptworse.hplScreenshot 2025-06-25 143507.png I have the log and tune and picture on here.
    North Carolina
    4,932
    There are still lots of torque limiters here
    try this
    1969 chevelle step 4.0.2 torque stuffs try this.hpt
    Jun 2016
    Tuscaloosa, Alabama
    82
    Thank you Alvin. I just bumped it all up and should have almost maxed it out. I didnt know it would make a difference on the one in transmission for torque stall. out of 175 tunes I dont guess i have come across that yet. Thanks again.
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,173
    try this
    Should he also set [ECM] 2869 - Delivered Torque Max back to stock? Right now it is 6,000 lb-ft.
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    North Carolina
    4,932
    I would.. but its a swap so it doesn't matter.
