Results 1 to 15 of 15
Thread: 2009 GMC Sierra 5.3 New Tuner
    Jun 2025
    Bend Oregon
    5
    I replaced broken exhaust manifold with long tube header and Cold Air Intake. Had no idea that I was about to fall into programming land. Truck runs bad and can't drive it. Bought hp tuner and started to watch videos and forums. I have deleted rear o2, dod, afm, and trans shifting (I believe I completed the tuning correctly).
    I ordered Wide Band o2 but will not arrive for 4-5 more days. Is there anyone with the same upgrades that could help me with a tune or look at my tune? I am out of time and really need my vehicle for tomorrow. 2009 GMC final.hpt
    Any help would be greatly appreciated.
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    922
    Can you make a log file?
    If so you can do alot with o2 error. Not wide open, but you can get alot done
    Jun 2015
    Aubrey TX
    922
    Also its good to post your stock Tune.
    People can look at what you have done and give very valuable feedback
    Jun 2025
    Bend Oregon
    5
    Thank you for helping me. I am really excited to learn this. I will go to my truck and figure out the Log file.
    Jun 2025
    Bend Oregon
    5
    Original Tune
    Please see attached
    Jun 2015
    Aubrey TX
    922
    I'm no expert, but I would definetly question the throttle Tip in torque adjustments. That could possibly lead to some driveability issues.
    I see what you have done, but I really don't think you are going to be Torque Limited with your modifications so far.
    If I'm understanding correctly your only modifications are Intake and exhaust?
    If this is true it should run fairly well, at least driveable, in stock calibration. The only thing I see that you have done to compensate for anticipated airflow is increase your base RPM and adaptive idle and thats really more for a bigger cam.
    I can say pretty confidently you need to put the adaptive idle adjustment back to stock for now.
    You might need to adjust your base running idle air flow.
    From my limited expearience, meaning just dealing with my own stuff, some MAF calibration and some VVE adjustment and possibly some proportional and integral delay on your o2 sensors should get ya going with you airflow. Maybe some timing.
    As for your transmission adjustment, shift time and very light shift pressure adjustments should have you pretty satisified.
    Please don't take this wrong, I just believe you need to redirect you focus for now
    EDIT
    I see you did dod/afm disable and PE... Those are both beneficial
    2,758
    How bad is it really running? If real bad, I would check the ignition components. Pretty common to damage a plug on header installation. Also check for exhaust leaks.
    And depending on what cold air intake, it might have changed the maf flow quite a bit. As a learning experience, I would say put the stock intake back on and tune for the long tubes first and then reinstall and complete the tune. Or not since they often don’t do much.
    Or unplug the maf and see if it runs better.
    Jun 2025
    Bend Oregon
    5
    What do you suggest the running numbers should be for idle airflow, MAF calibration, VVE adjustment and timing?
    Jun 2025
    Bend Oregon
    5
    Thank you! I replaced the plugs and wires after the header install. It is pretty rich from the smell of the exhaust. I looked at the DTC'S and they denoted both rich and lean conditions were present. Also, as for the exhaust leaks, I retightened everything and it looks tight. It's not terrible running but just don't want to hurt the vehicle. Thank you for the welcoming to the Forum. I am truely amazed by the kindness/ willingness to help me. I am a person that will pay it forward!
    Jun 2015
    Aubrey TX
    922
    That is what your logs will tell you.
    I'll try and load you a basic channels setup. Then you can log a start, idle, and light driving (if applicable) with very slow throttle movements to 1/2 throttle or so.
    Jun 2015
    Aubrey TX
    922
    PM me an e-mail if you would like. I have a 3 slide power point that shows how to upload those channels
    Arizona
    1,259
    Quote Originally Posted by dhoagland View Post
    why not just post those 3 pictures here for anyone else in the future that might need them..
    PMs are great for personal info, but, things that help others should get posted for all to see
    Jun 2015
    Aubrey TX
    922
    Good Point..
    Pictures are screen shots directly into a power point. I can't seem to figure out how to copy them from the power point and save them as something I can upload here.
    2,758
    Good Point..
    Print to a pdf? Rescreen shot and save as jpg?
    Jun 2015
    Aubrey TX
    922
