Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Day 1 2013 Tahoe 6.0
    Jun 2022
    17
    Ran today with attached tune. Used components from L96 Express idle and airflow to test effects on power and startup idle. Start up was idle was still fluctuating but at higher RPMS so it didn't dip low enough to sound like it was going to stall out. Power was good but the throttle was not crisp like before. I tried to save a log file but I did not save it correctly, any guidance would be great.
    Jun 2022
    17
    Ran attached tune with log file results drives fantastic but still has initial startup idle fluctuations.
    Jun 2022
    7
    Can you confirm is there limp issue when press accelerator paddle aggressively? As I can see you have tuned MAP A throttle response
    Jun 2022
    7
    Can you confirm is there limp issue when press accelerator paddle aggressively? As I can see you have tuned MAP A throttle response.
    Jun 2023
    8
    Looking at some of your attachments for e38 12613412 injector data and none of them are working? Have one handy? Returnless fuel system
  6. #26
    Dec 2019
    MS
    1,205
    Quote Originally Posted by Rush2252 View Post
    What are you working with or what do you need?
