03 chevrolet silverado 5.3 gen 3 with long tube headers and 4" exhaust.
stage 4 truck cam v2
prc heads
i recently removed the supercharger that was on my truck and the previous owner had a stage 2 comp cam with a magnuson supercharger on it.
i installed a stage 4 truck cam v2 in it and installed a tbss intake with a 92mm ( i believe ) jegs throttle body and 50 lbs injectors at 58 psi.
the previous owner had a handheld and hptuners he tuned the truck with. i have little experience with hptuners but i have used the holley efi and terminator systems before.
the issue i am having is my truck has almost no take out until it hits about 4000 rpm. i have gone through and adjusted everything i can possibly think of to get it to pull. it pulls strong over 4000 rpm but it wont spin tires and it feels super weak getting to the 4k rpm mark. ei know it runs pretty lean at idle but ive heard it doesnt do any harm running lean while cruising or at idle/ low rpm in gears. any help would be appreciated.
dadscurrent3test.hpt25-06-28 20-20-28.hpl
