Results 1 to 20 of 20
Thread: Whos used one?
    Sep 2021
    Kentucky
    1,850
    Whos used one?
    Anyone used a core ecu yet?
    Banned
    Jan 2022
    fountain valley
    2,379
    Prolly gonna have better luck finding people talking about it over at yellow bullet or the likes
    Jan 2025
    4
    I have one
    Nov 2011
    10
    Set one up on an LS in less than 20 min
    Quote Originally Posted by deeskx View Post
    I have one
    Just got back from a small training seminar at HP Tuners. It only took me about 20 minutes to get it running from wizard to fire up on an LS1 on their test firebird. Some things were me being OCD but its no harder than any other product on the market if you know what you are looking for.
    I’m curious if this removes the need for a lingenfelter 24x to 58x trigger box for older gen 3 ecu’s?
    Dec 2019
    MS
    1,264
    Quote Originally Posted by 2000Phoenix View Post
    Should just be a setting to control either reluctor just like all the other aftermarket ECU's.
    Maybe hptuners can chyme in on if this is true. Don't want to purchase something so expensive if I don't know for sure that is an option for the ecu.
    RDF1 is right, CORE supports both 24x and 58x reluctor wheels. You just need to set the correct setting in the tune file.
    Dec 2019
    MS
    1,264
    Quote Originally Posted by Victor@HPTuners View Post
    can you mix/match the crank and cam?
    24x/1x - 24x/4x - 58x/4x - 58x/1x
    So to confirm if my new build is 58x trigger and 4x cam gears there is no need for the lingenfelter box correct? This ecu allows you to change to whatever the engine specs are?
    Quote Originally Posted by RDF1 View Post
    For 24x, only 1x cam is currently supported.
    For 58x, both 1x and 4x cam work.
    It is always advised to use a timing light to ensure correct angle.
    Correct, you would not need the lingenfelter box. We support 58x/4x.
    Quote Originally Posted by MarkS@HPTuners View Post
    Thank you for clarifying. I have a gen 3 p01 drive by cable engine is a 58x trigger so which harness would I need and does it matter? Also what’s the warranty for these?
    24x Drive-By-Cable Harness
    58x Drive-By-Wire Harness
    15′ Flying Lead Harness
    We do not offer a harness that would directly suit your needs as the cam and crank position sensor connectors are different between a GEN 3 LS and a GEN 4 LS. The 24x Drive-By-Cable Harness would be the closest match that we directly offer on our website. The only thing that would have to be changed/modified from the 24x Drive-By-Cable Harness is the cam and crank position sensor connectors.
    We work with EFI Connections who can make you a CORE ECU 24x Drive-By-Cable Harness with the appropriate 58x/4x cam and crankshaft position sensor connectors.
    If you would prefer not modifying the 24x Drive-By-Cable Harness we sell, then please reach out to EFI Connections directly with this specific request.
    https://eficonversions.com/pages/contact-us
    Quote Originally Posted by Zach@HPTuners View Post
    So my harness would have to modified or can I get some type of extension harness? Or is it not that simple?
    If you were to buy a 24x Drive-By-Cable Harness we sell on our website, then yes the cam and crank position sensor connectors would have to be changed. Whether that is modifying the harness yourself or using an adapter (if available 3rd party), would be up to you.
    Otherwise, you can contact EFI connections to build you a CORE ECU harness (with the right cam and crank position sensor connectors) to suit your specific application that would not require any adapters/you having to modify a harness.
    Thanks for clarifying I was not sure how to tell them what I need. To clarify I’m giving you all info engine is a gen 4 427 58x triggers going in a 2000 fbody. I will reach out to them to compare prices and pros/cons vs changing reluctor wheel ect vs the lingenfelter box.
    So it is a gen 4 engine? If it is a gen 4 engine that is using a cable throttle body instead of an electronic throttle, then this is type of harness is already offered by EFI Connections.Screenshot 2025-07-16 091902.jpg
    So they got back to me and only stated they have crank sensor adapter harness p#6011 and cam sensor adapter harness p#6014. I forwarded our correspondence to them so they not understanding what I’m asking. Can you confirm which one I need since I have a cable tb on current set up. Sounds like maybe they don’t think I need it since they didn’t mention it. Per the pick you sent I guess I need the manual one. I will try to ask them again in a different way to clarify.
    That part number saids it’s in the works and coming soon. Is there another option?
    Efi got back to and stated CORE ECU will work with my current cable throttle body. Is this accurate?
