Results 1 to 10 of 10
Thread: 2015 ls3 e38 stand alone starts and dies
    Apr 2012
    4
    Any help would be much appreciated vats is disabled
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Tune/log
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Apr 2012
    4
    ls3 e38 standalone tune
    Here is my tune. thank you
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    VE tables are all 0's. Has to be populated now that you've done the 2 bar OS. It starts out blank...
    Also the MAP sensor settings have been changed to a 2 bar sensor. If you didn't change the sensor then those need to be changed back. Airflow-->general. MAF sensor linear, original value was 128.13 kpa. Offset was -0.31 kpa. Make sure you're in kpa.
    Attached is one you can try as a starting point. Airflow-->general, "Normal IMCR Closed" and "Normal IMRC Open". Paste the table in the attached Excel file into both, change the MAP sensor back to the stock values (unless you physically changed the sensor) and see if it'll start.
    VE.xlsx
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Apr 2012
    4
    Thank you for your help! I did what you said and it fired right up. I feel kinda dumb now though this was a take out package out of a wrecked
    2015 chevy SS with 9 miles on it from a salvage yard so I assumed it had all the stock settings in it. I turned the vats off and the emissions codes and changed the fuel pump settings. Were the VE tables from a stock SS? The only things done to this engine is mid length headers and an air intake. Its in a 73 RS Z28 Camaro I'll post some pics in the next day or so.
    Thanks Again
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Someone did the 2 bar OS upgrade... it would have never started with the tune that was originally posted
    Jul 2025
    Quote Originally Posted by Tom355 View Post
    Hi I?m having the same issues on my ls3 6.2 Camaro I did the vats and here it goes it starts and dies after. Second can I use you you?re tune ?
    Tuner DanN's Avatar
    Jul 2019
    Shuswap, BC, Canada
    59
    Quote Originally Posted by Dm kustoms View Post
    You should post the tune and a log of what you have now.
    The tune Tom355 posted was incomplete.
    1972 Triumph Spitfire Ecotec Swap:
    Stage 1: MEFI-4B & L61 - deceased; ate it's own balance shafts - because I did a dumb.
    Stage 2: E37 & GenII L61 - Ran great, but too meh.
    Stage 3: An LSJ is a good time in a 2000# car.
    2005 GMC Canyon base work truck.
    LS Swap, AR5 Trans, BCM transplant, Sierra Dash, G80
    5BA8
    5,491
    He should start his own thread instead of bumping a nearly 10 year old one.
    email=[email protected]
    Tuner DanN's Avatar
    Jul 2019
    Shuswap, BC, Canada
    59
    That too, but kudos for using the search function, I guess.
