Results 1 to 15 of 15
Thread: Please help with stalling issue
    Jun 2020
    Ohio
    15
    Hello I have an issue of stalling about everytime i come to a stop. It makes it pretty hard to get any good data to get my ve sorted out.
    My setup is as follows:
    lq9 shortblock with sloppy stage 2 228/[email protected] 112 lsa
    LY6 rec port heads
    ls3 intake
    12631214 flex fuel injectors
    DBC truck throttle body adapted to the ls3 intake
    headers and 4in single exhaust
    tko600 trans
    ls2? i think 3-wire maf (disabled to tune ve)
    p59 ecm from 2005 express with drivers for iac and tps dbc..
    (note on pcm, I had originally os swapped it to 12592618, a 2005ish export 5.7l vortec tune as i was going to use on a 4x sbc conversion. that had other issues so i ended up segment swapping a 6.0l dbw and manual trans tune and turned off the dbw stuff in the systems tab. I also found a 2003 6.0l dbc tune and copied all the settings I could in the electronic throttle tab. I did not go back to the 2005 express dbc os 12587811 since i was unable to find a manual trans segment for that os)
    I dont know if possibly I created a bunch of issues by doing all the os swapping stuff.
    I've played around with the throttle follower and cracker and braf some but it didnt seem to do much below like 1000rpm. Car will start and idle nice and the iac does operate as it should seems like.
    Would someone mind maybe taking a look at the tune and log to see if anything stands out?
    camaro idle1.hpt25-07-17 19-23-45stall.hpl
    The stall happens around 1:00 into the short run.
    Thanks for your time
    Indiana
    465
    I dont have data for those injectors, but all the necessary parameters were altered, so I'll go on the assumption that theyre correct for now. Not much underspeed spark to try and save it, I added some for you. Timing tables look bad around idle and all over. Huge valleys and dips its has to overcome if it hits those areas. I smoothed those out for you as well based on stock timing tables and what changes you had.
    No guarantees, but heres an altered file....
    "It'd be a lot cooler if you did."
    Dec 2019
    MS
    1,317
    Are you sure of the injector part number?
    That 12631214 is a crank sprocket.
    North Carolina
    4,929
    IMHO desired idle speed is too low. I'd go 800 since you are a manual. if it was an auto maybe it would do ok at 700.
    I'd also encourage using a wideband to get the VE fully flushed out as the fuel trims move to slow to capture how rich or lean it might be in decel or idle dip areas. Use fuel trims as final say.. but the first several passes should be done with a wideband.
    Senior Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    1,022
    Desired Idle RPM
    Not sure if this might help, and I'd also like to know what determines Desired idle RPM (I will search later but dont have time right now.
    While looking at his stall condition I noticed when he was dropping RPM and got to his base set point of 700 the timing was still at 21, which I thought surely should be enough to keep it running.
    So I started thinking air flow. Thats when I noticed the desired idle rpm in the log at 625, obviously well below the base set point. So I'm thinking any and all stall savers are off the table aty this point
    Then after the stall and restart, the desired rpm seemed to match the table.
    BUT then at the end of the log it is back down to 625, just as it was at start up too
    Jun 2015
    Aubrey TX
    1,022
    IAC Effective Area
    Curious where the 200 comes from for IAC effective area MAX?
    Indiana
    465
    I saw that as well and compared to a few files. I had no idea where it came from so i just left it, IIRC. I wanna say the file i had, it was in the 80's, not the 200s
    Jun 2020
    Ohio
    15
    Quote Originally Posted by RDF1 View Post
    Sorry it?s 12613412. 50lb flex fuel injectors.
    Jun 2020
    Ohio
    15
    Quote Originally Posted by dhoagland View Post
    I see what you mean about that number not making sense. I copied some parts from another tune I had done for another vehicle and didn?t notice that being different than the 4 or 5 other downloaded tunes I?ve compared to for the throttle stuff. I?ve been copying parts from a dbc throttle tunes to makes sure I can get as much as I can right.
    I will change that back to a lower value I?ve seen in other tunes.
    Jun 2020
    Ohio
    15
    I was wondering about that. For some reason this cam doesn?t seem to lope very much at all. I wonder if it was a knockoff in an Elgin box? When I installed I just quickly checked ptv and put it together. I guess I will have to check into that also.
    I haven?t tuned much of the ve yet due to the stalling coming to a stop. I could plug the wideband in and tune the idle areas though since it will idle all day good.
    Jun 2020
    Ohio
    15
    Quote Originally Posted by horsepowerguru427 View Post
    Thanks for checking that out. I will plug it in and see if it helps.
    Jun 2020
    Ohio
    15
    Would it be a good idea to swap os to something I can get dbc and manual trans on the 1mb p59 and start over with a fresh tune? Would being a 5.7l l31 vortec base tune with a 6.0l segment possibly leave unseen tables incorrrect?
    Indiana
    465
    Quote Originally Posted by Kzhurley View Post
    I double checked the injector data with what i have for 12613412 and you data was close enough. There were a few cells on the Vac vs volts that was off a very small percent but other than that it was spot on.
    Jun 2020
    Ohio
    15
    I am also unsure where that 625 is coming from. Could it possibly be leftover from the l31 5.7l vortec export tune i used for the base os?
    Jun 2015
    Aubrey TX
    1,022
    I guess it could be. But the big question, what table is driving it...
    This is one I'm going to continue to try and figure out. I went back and looked at some stalls from an LQ4 I'm helping a guy with and the only changes in his were higher commanded after the restart that matched the "start up" added rpm and then watched it phase out.
