Results 1 to 15 of 15
Thread: Help with Tuning
    Jul 2025
    6
    Help with Tuning
    I just need a couple people that have a little tuning experience to take a look at this tune I bought
    1999 Sierra 1500 5.3 LM7 2WD with high compression flat top pistons
    - BTR Truck Norris High Lift Cam
    - TBSS Intake, 92mm TB, GM 50lb/hr 58psi injectors (pt#12613412)
    - Longtube Headers
    Il Include a couple Logs aswell PLEASE HELP
    Tuner in Training fourninesfine's Avatar
    Dec 2023
    Upper Michigan
    40
    Not enough channels in your log. Add these and take another 5-10 minute log.
    E67_All.Channels.xml
    2010 Cadillac CTS-V (LSA/6L90E, E67/T43) - 211/230/122.5 .562/.562 camshaft (stock LS9 cam), 2.55" pulley, solid isolator, Airaid intake, ID1050X injectors, reinforced intercooler, C&R heat exchanger, EOS test pipes.
    2005 Cadillac Escalade ESV (LQ9/4L65E, P59)- 212/218/112 .600/.600 camshaft, LS7 lifters, hardened pushrods, captured rocker arms, LS9 head gasket, ARP head studs, true dual exhaust with long tube headers and x-pipe.
    Microsoft Surface Pro 8, AEM 30-0310 in-line wideband.
    Oct 2004
    737
    The tune is start over from scratch level garbage, so I did not even look at the logs.
    Indiana
    465
    Quote Originally Posted by 101thines View Post
    - Longtube Headers
    Wheres the original tune? It looks like someone took a truck tune and copied tables from a vette or a camaro file in places. That tune is awful. Start over and put the right injector data in FIRST. Tune the Air model then idle.
    "It'd be a lot cooler if you did."
    Feb 2024
    393
    Were you adjusting the VE without the MAF properly disabled? There is a pending P0102 code, so there is something going on with the MAF. However none of the steps were taken to ensure it was forced into SD mode. You also need to copy the corresponding rows of the primary VE into the Secondary VE after making changes to the primary on this OS, it defaults to secondary VE with a failed MAF. If you are running fixed 58psi fuel pressure your injector data is wrong, it is setup for a vac referenced pressure regulator. As stated above, try again, get your injector data setup right first before making any changes.
    Dec 2019
    MS
    1,317
    - Longtube Headers
    Hope you didnt pay too much for that.
    Here is the tune with correct inj data atleast.
    Lots of questionable things in that tune and the datalog shows the MAP senor giving some crazy readings or you have some serious misfires from Spark or Fuel missing and Fuel trims begging for help.
    And do you have a wideband?
    Jul 2025
    6
    Quote Originally Posted by RDF1 View Post
    yes i have a wideband, but i recently just went true dual so its only reading 1 bank. when my maf sensor is plugged in it reads lean asf like 20, but when its unplugged it reads closer to normal like 14 until i get on the throttle then it goes lean again
    Jul 2025
    6
    Quote Originally Posted by gametech View Post
    i just started learning. i knew it was ass. i got scammed
    Jul 2025
    6
    Quote Originally Posted by twenglish1 View Post
    one of the logs is with the maf unplugged and one is with it plugged in. ig the secondary table is closer to being right. ND also i didnt tune it "the scammer" did
    Oct 2004
    737
    I hope you did not take my post the wrong way. It is just useless to look at current logs when the tune they are from needs to be completely redone. And over 20 years ago I started learning to tune for myself because of a garbage tune that I paid for. The situation has only gotten worse over the years with people selling crap to people who don't yet know any better. Live and learn.
    Arizona
    1,323
    The situation has only gotten worse over the years with people selling crap to people who don't yet know any better..
    my buddy paid for a tune recently. The guy came to his place and uploaded a tune, started it idled it, revved it up and then said he was done and left. NO driving, no warming it up to op temp, just idled and rev'd.. id be so ashamed of doing anything like that
    Jul 2025
    6
    oh no man i understand. i literally just bought my mpvi a couple days ago to look at the tune and learn, it looked like crap to me as well thats why i came here to get more opinions. THANK GOD my motor aint blow up.
    Appreciate everyones feedback also do you all know any good courses to take for learning
    Senior Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    1,022
    Quote Originally Posted by bk2life View Post
    Unvelievable and so dissappointing...
    Dec 2019
    MS
    1,317
    Oh thats common around here. Their idea of "Tooning" is just to get it to idle.
    North Carolina
    4,927
    - Longtube Headers
    In the transient section you need to reduce or zero out the min fuel milligrams and PW since you have larger injectors. I made a post about this a while back. But yeah this tune is so bad that you should start over.. else some dumb change that didn't need to be made could haunt you later.
