Thread: Another noobie here trying to learn
    Jul 2025
    Hey all, Name is Steve. I'm new to tuning, trying to learn. I have an extensive background in automotive, but tuning is fairly new to me. Anyways let's dive into this. My car will be "track use only".
    I have a 05 Dodge magnum, had a locked-up motor. I pulled a motor from a 07 Ram 2500, went through the engine, verified all internal components were in good shape (motor had roughly 20k on it) and then swapped over the needed parts from the car engine to the new engine. I purchased a kit from AMS racing, cam - Texas speed cam stage 2 non VVT, PAC springs, pushrods, hellcat lifters, timing set, MDS delete and a new oil pump. PHEW!
    So, now we are here. I have the engine installed, performed all my relearns. But the engine will not idle, it will start and run with the throttle pressed. I cured all check engine lights that came on after installing and I have been poking around on HP tuners a bit. I have gone in and deactivated the MDS and deactivated the EGR for now.
    I have been reading this forum a bit, and I came across one thread where the setup was similar, and one suggestion was to "bump the idle to 800, pull 20% fuel out of injectors or VE table in the idle area between -5/+5, depending on how loopy of an idle you want, and pull about 20% on the torque management table".
    I am still learning all of this, and I will give the suggested idea above a try. Is there anything else I should look at or adjust beforehand?
    Thanks everyone, I appreciate any and all help
    May 2025
    Idaho
    8
    Ever get this figured out? Working on something similar myself.
    Senior Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    1,029
    Quote Originally Posted by cr8tor View Post
    I'm not a Dodge guy at all...
    But if you post your tune file with a log and all of your modifications you will usually get better responces.
    I might be able to help at least make ity idle..
    Aug 2021
    Indianapolis Area
    468
    Quote Originally Posted by SJacksonWWCC View Post
    Are you still facing this issue?
    DodgeBoy.
    Email / Remote Tune: [email protected]
