Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 101 to 120 of 198
Thread: knock sensors ?
  1. #101
    Senior Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    1,029
    Quote Originally Posted by mychevyisntheavy View Post
    i think i got it. i think i got the ve to a point of mybe one more tune. then the maf. then this thing will be tuned. whjat you guys think i took the ve started in the middle like started with 400rpm .5%-4400rpm to the top added 9.5%,then 4800rpm add 10% from 105kpa tp the top, then from like 5200rpm to the top add 9.5%-6400rpm from 105 to the top with.5% reshaped the ve . it looked really good, i loaded in and did a log, man it loved it. green everywhere expected for like two to three spots. so ilogged and tuned here is the tune after me up loading the log on to the newer ve i think i got it
    Much better
    You're getting the hang of it....
  2. #102
    Nov 2024
    Louisville, ky. Portland
    251
    Quote Originally Posted by dhoagland View Post
    Much better
    its taking me forever tho, i just hope i dont screw it up. ive moved on to the maf, i might once i get the maf done go back and do the ve again. if it wasnt for you guys id never figure this out. it has stopped that idle heckup.
    2003 gmc rcrb black.5.3, 4l80e.
  3. #103
    Indiana
    467
    It takes everyone a while to learn, man. Even the senior guys in here are still learning stuff. Its always evolving... Its not easy stuff to do or wrap your head around even if youre very familiar with cars. Its definitely rewarding when you do end up getting everything to fall in line and run right though.
    "It'd be a lot cooler if you did."
  4. #104
    Jun 2015
    Aubrey TX
    1,029
    Quote Originally Posted by horsepowerguru427 View Post
    I'm often humbled when I use the other platform for Diesel stuff..
    Its almost like being decent with windows computers then switching to MAC... All of the sudden you remember what it was like at the begining of your journey...
  5. #105
    Sep 2009
    1,184
    I have been tuning GM ECMs and PCMs for 20 years and I still learn new stuff and improved methods regularly. I have touched up tuning on many vehicles I tuned 10+ years ago as well and been like WOW. The stuff that we did not know even 10 years ago about these Gen III controllers could fill a 300+ page book with ease. I have considered writing a book myself purely on Gen III operation, wiring, conversions, tuning and scanning. It would cover advanced settings and tuning not avaliable in HP Tuners without user defined parameters as well such as making flat response knock sensors work correctly.
  6. #106
    Jun 2015
    Aubrey TX
    1,029
    Quote Originally Posted by Fast4.7 View Post
    I'd defintly be interested in that
  7. #107
    Indiana
    467
    Id definitely buy a copy, dude. I try get my hands on anything and everything i can to increase my knowledge.
  8. #108
    Nov 2024
    251
    id buy one for sure, i buy everything under the sun to try to figure this out, but im throwing my towelin, its knocking or ping under power, so im done im gonna put this thing in speed density and wait on my heads and things to get this dyno tuned. im done. this is the main tune, and the log i just did.
  9. #109
    Nov 2024
    251
    a i redid the low spark table on this tune what you guys think. im just at my end.
  10. #110
    Jun 2015
    Aubrey TX
    1,029
    I get your frustration. I was going through your first log posted this morning and saw extream differences in the exact same cells...
    If I understand correctly you are using AFR error in your charts?
    You almost have to be since your wideband is in AFR...
    Look at this picture and notice the commanded AFR is clearly at 14.68 but you are in "open loop accll" mode. The commanded EQ ratrio of .85 confirms this. I saw this in mulitply spots on the log and it stayed that way all the way through the screen so its not just lagging behind.
    This is showing extreamly rich error in the log (Yes the 10.92 on the wideband is rich, but the error is against 14.68 commanded vs the 12.XX that is should be)...
    Maybe I'm missing something, but if not these error logs are going to have you chasing your tail
  11. #111
    Jun 2015
    Aubrey TX
    1,029
    And yes. The commanded AFR did change at some points throught the log, but it was more often pinned at 14.6
    What is the sampling rate in your charts for the commanded AFR?
  12. #112
    Nov 2024
    251
    so is my aem wideband not calibrated right. is this why im chasing my tail. i followed the aem instructions. its a 30-0300 x-series uego. this is the one i have, i have another wide band on the truck its not hooked up to the hp tuners. i watch it sometimes to see if its the same. its on the passenger side and the aem is on the driver side. just how the bungs are made in my headers
  13. #113
    Jun 2015
    Aubrey TX
    1,029
    Low spark table looks better...
    I know you're tired of heraing me say I think your high table is too high for where you are in this tuning process, but fortuntaely the KR is helping ya out here...
    I also must admit when you were SD I didn't see KR issues..
  14. #114
    Nov 2024
    251
    i only did the low at that time,, here is the tune i did for the spark tables.
  15. #115
    Jun 2015
    Aubrey TX
    1,029
    No..
    For some reason the commanded AFR channel that you are logging is not switching away from commanding stoich, which in your tune is 14.6
    Look at the Equivilance Ratio Commanded channel.
    See how it goes from 1 to .85 when you get into PE (open loop accel)... This also matches your wideband going from 14.6 to 10.92 in the log
    Everthing seems to be working Except the AFR commanded channel
    So your graph error is against an incorrect variable...
    If you would like I coyld take a stab at adjusting your MAF curve based on closed loop LTST fuel trim error, and gestimations of MAF airflow and probably get this smoothed out a little
  16. #116
    Nov 2024
    251
    No..
    please,
  17. #117
    Jun 2015
    Aubrey TX
    1,029
    Not going to lie... I'm not to sure what to do here.
    These next 2 pictures show your wideband going from 11.8 while being commanded 12.5, which is okay, to 18.5 while still being commanded 12.5. Obviously a big concern
    Not much changed between these 2 screen shots (same screen just moved curser to show the 2 different points)..
    Really until this gets figured out, which there could be a simple explination I'm over looking, I really cant see making any helpful changes.
    I'll be happy to continue to help, just can't do much with this perticular log
  18. #118
    Nov 2024
    251
    aaaaaaa... i did something wrong .... it was in the open loop (eq ratio) i lowered it dont know why i messed with that, but i put it back to 1. i think it was part of my mess. smh, here is a log and the tune with changes back to 1 in op temp of the eq ratio
  19. #119
    Nov 2024
    251
    in speed densty and maf it was set to one. dont ask why i changed that , smh. the tuning for both was dont set to 1, now the blended tune is at 1 now
  20. #120
    Nov 2024
    251
    here is two logs on the tune that is bleeded and eq set to 1 at op temps. drove to the store, log two different times same tune.
