Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: cannels and charts for newbie diags?
    Jul 2022
    Texas
    130
    Quote Originally Posted by w313zrd View Post
    i dont know how to thank you appropriately. the "hunting" is pretty much gone. flashed before a trip home. will do a soak start in a bit to see complete picture. after the initial, as expressed, computer settling to the tune; it is no longer hard bouncing below 500rpm. 99% of my "feel" issues gone. so far so GREAT! thanks again!
    Glad it helped you and got things going in the right direction. You could log it and look at Zero Pedal Torque so see if it needs a tiny touch-up in the Virtual Torque Tables. After that, then you can decide how much you want to chase the fuel trims. The nice thing is since it's running well, you can experiment knowing that your focus is really two areas...MAF and VVE. Make a change, if it move fuel trims in the right direction...Great! If it goes to crap, scrap that those modifications and make a different set of changes.
    Enjoy!
    Jun 2025
    27
    Quote Originally Posted by 96GS007 View Post
    Enjoy!
    sorry for the delays, been running with that provided tune, for a week or so... went out today, did three logs, cold start, long drive, longer drive. https://drive.google.com/drive/folde...Js?usp=sharing dated 7/26/2025-3logs. . ...on to understanding the MAF/VVE tuneing protocols/procedures... thanks again. seen no issues while doing those logs. but the ambients been lower today fyi.
    Jul 2022
    Texas
    130
    I looked at the long drive. The VVE and MAF are consistently rich. Just my opinion, but I think you could do a "global" change in the areas you have good data and a little smoothing around them. Then see where the fuel trims end up. Something like reducing the both of them by 10%. If things look better and it's still running well, then you can fine tune as you see fit. I did notice you have a little spark retard of a bit over 1* from 600 to 1200 rpm if you look at the peak value and not just the average. Probably nothing but after the fueling is done you may find you need to do a little nip & tuck on the spark table.
    Jun 2025
    27
    thanks again.
    gonna try some adjustments today.
    given the last log file, i have modified some tables...
    base: starting point 20250714-flexdelete VTT & Adaptives.hpt
    1st iteration: tune 20250727_iteration_1ve_1MAF.hpt
    i dont think i have made any big or detrimental swings. will drop it in and log after after she warms up
    still a ways to go... the logs: after 1st iteration
    https://drive.google.com/drive/folde...F4?usp=sharing
    Jun 2025
    27
    Attachment 163123 <-- curve from stock table. given i dont have data for this area to make data driven moves, is smoothing that saddle out like this a viable move? >Attachment 163124
    proposed next iteration:PROPOSED_20250727_iteration_2ve_2MAF.hpt
  6. #26
    Jul 2022
    Texas
    130
    Progress!
    Couple things....
    - On your MAF adjustments, if you look at 2700 Hz, you have a dip. I'd smooth forward of that just slightly and back to ~2300Hz to get rid of the dip.
    - Your Zero Pedal Torque is creeping up so you may need to massage the VT tables again in the idle areas
    - I think the VVE changes look reasonable
    I'd smooth the MAF curve and then run that tune. If the fuel trims look better but you're having the idle issues again, I'd update the iteration 2 file by tweaking the VT tables to address the Zero Pedal Torque
  7. #27
    Jun 2025
    27
    Progress!
    Couple things....
    for that (the vt edit) should i compare the stock tune to the edits you provided(a tune) earlier in this thread to understand what to adjust further or is there a resource out here for me to glean some more knowledge on those adjustments? and thanks for the finer tuning suggestions. really appreciate the help!
  8. #28
    Jun 2025
    27
    Progress!
    Couple things....
    iteration 2: logs and tune https://drive.google.com/drive/folde...-9?usp=sharing will do a longer log on the way to work tomorrow. got alot more throaty when second gear hits. even light throtle. i dont mind. kinda that old 4barrel opening kinda thing. atleast in my head. but it may be a little much...
  9. #29
    Jul 2022
    Texas
    130
    I did a touch of smoothing on the MAF curve and some nips and tucks on the VVE table where you're still rich in the 550/600rpm range as well as an area where there was a potato chip shape. It's not an area you'll drive in but it looks better
    Take a look and you can run it or change it as you see fit. I didn't do anything in the VT tables. Zero Pedal is still a little positive but nothing outlandish that can't be touched up later. Ditto the timing where I still see a tiny bit of spark retard but nothing I'd lose sleep over
    As always....if it runs like shit, default back to the prior version. I'd say that where it's at right now is darn close to some of the values I've seen when people log stock tune files so this one is an attempt to go beyond that.
    I freely admit I'm slow. I'm sure one of the guys that does this for a living could whip it into shape in no time but since 1) this is not my vehicle and 2) I don't do this for a living.....I like to be cautious.
  10. #30
    Jun 2025
    27
    appreciate the tweaks, was able to drop that in before lunch, drive back from lunch25-07-28 11-34-04.hpl dry conditions. then on the way home(it was pouring rain) https://drive.google.com/drive/folde...NL?usp=sharing. wasnt able to get any freeway in in these logs... i drive a mix, probably should tune given that mix.. thinking i need to dedicate some time, drive typical drives, and as was said wash rinse repeat...
    thoughts on keeping the MAF table as is now, and roll back the VE even back to stock, or best to roll back both the same time?
    i probably went a little far with some of that smoothing. never got this much intake audible feed back till i was on the pedal... NOOB liberties got me paranoid. (vibes ok from time to time, vibes all the time break/compromise parts)...
    highway drive on way to work this morning added to the google drive "3"
  11. #31
    Jul 2022
    Texas
    130
    My opinion is that I'd leave the MAF alone or some very minor touch-ups. In general the averages are +/- a few percent and to me that's good enough. If one of the experts is watching this thread, I'd welcome their input. I look at the fuel trims using Cringer's graphs, typical "LTFT vs MAF Freq", I have another look with the STFTs and LTFT, etc. I think there are elements of all that are value-added since it's a dynamic environment.
    Regarding VE, it looks like it just needs more massaging in the 1400 rpm area so I'd work on that.
    Zero Pedal looks really good at -3 or so on average.
    How's the quality of the drive? Good idle? Good take off from a stop? No throttle hang? Bucking or surging at part throttle? Any smells/fumes? Once you reach the "it drives fine" stage it becomes an issue of how much better you want the data to look even though it has no impact on what you feel regarding driveability....you're just chasing numbers.
  12. #32
    Jun 2025
    27
    thanks again for your assistance, if i get to texas, ill owe ya a beer or sandwich what ever your pleasure!~
    drive-ability was suffering a bit, that saddle/chip shape controls more than i understand. ive rolled back the VE to before i got silly with the "smoothing"
    https://drive.google.com/drive/folde...3G?usp=sharing that latest tune , and two logs, got some data for maybe another round or two.
    idling pretty smooth, diving great, no issues so far. well-then.png maybe im good...
  13. #33
    Jul 2022
    Texas
    130
    No worries, glad things are working out.
    I looked at the large log and it looks like there was a lot of spark retard.
    I think I'd go back to "20250727_iteration_2ve_2MAF-smoothed - Rev 1.hpt" if it was driving well and then just minor VE changes at most. Frankly I think I'd leave MAF and VVE alone. Again...if that version was driving well, you're just chasing numbers at this point. Also in that version,
    - Zero Pedal Torque looks good. You could make it go negative with a super small tweak....like subtract 1%....to the VTT in the idle area and then smooth to the right
    - Idle timing looks good being positive and right around 7* or so
    - Predicted vs Delivered Torque all looks good
    About the only thing I see is that your spark table is pretty choppy so that will contribute to driveability "goodness". Do you have the OEM table? Not sure I've seen one that has that much advance in some areas and the various spikes and valleys. I circled a few of the spikes and such in the screenshot.
  14. #34
    Jun 2025
    27
    stock base tune i belive1496595828-2017silver-base-computer-flash.hpt
    may try as suggested and look to make a pass at the spark. drive-ability wise on that one: low pedal getting thru the neighborhood feels like the cam tips open and shes too loud. personal issue im sure, but i can probably tune that out within the VAR-CAM area... and would get me more hits on the error given the low rpm ares i drive in... again appreciate your inputs.
    ~Will
  15. #35
    Jun 2025
    27
    i still may go back to a previous iteration but on my learning path i touched up the VVE, threw it in and took a mixed drive over lunch. everything seems fine(still aint touched the cam, or spark). tune and log: in this drive folder https://drive.google.com/drive/folde...d-?usp=sharing . still a bit of work i think. new skills need honeing..im a work in progress, like this truck.
  16. #36
    Jun 2025
    27
  17. #37
    Jul 2022
    Texas
    130
    Trims are looking a bit lean on that one, both MAF and VVE. I'm getting ready to head out of town for a couple days so I won't be able to look at files. Regardless, look closely at the fuel trims.
  18. #38
    Jun 2025
    27
    no worries... went thru a bunch of vve edits and im back to the stock vve, and what we finally came up with on MAF 20250801_rev2_MAF-ONLY_VVE-STOCK-closed.hpt
    im good for now... https://drive.google.com/file/d/1g4f...ew?usp=sharing
