Does anyone know if the signal expected is;
0 volts = 0% ethanol
1 volt = 20% ethanol
2 volts = 40% ethanol
3 volts = 60% ethanol
4 volts = 80% ethanol
Last edited by stingray22; 3 Weeks Ago at 02:37 AM. Reason: typed the same msg twice
Just tested pin 6 and found it had 12 volts on it. Also the wire on pin6 runs across to pin 20 on the fuel pump power control module.
So I don?t think this is right.
Should be a PWM signal, not voltage. Gen4 stuff is as follows
50 Hz = 0% eth
51 Hz = 1% eth
149 Hz = 99% eth
150 Hz = 100% eth
The telltale sign will be on the Flex Fuel tab, is a default frequency listed?
<<< A standard approach will give you standard results >>>
My Free Tuning Software:
MAF Assistant
EOIT Assistant
Flex Fuel on the C8s doesn't go to the ECU Pins.
So far I've seen it's just with vehicles running the Global E99. So the C8s & Eray, the CT5Vs, the CT4Vs, and the Escalade V.
For global B vehicles (cars) it doesn?t pin into the ecu. Even once pinned you have to modify the actual code to enable it. We can do this for you as well. I dont get on here often but feel free to find me on Fb or IG
For global B vehicles (cars) it doesn?t pin into the ecu. Even once pinned you have to modify the actual code to enable it. We can do this for you as well. I dont get on here often but feel free to find me on Fb or IG. may make more sense if you know who i was lmfao. forgot that i had this profile on here.
