Dear,
passenger side kick panel mini fuse #29(C/LALDL) is blown. replace it and enjoy your tuning.
Dear,
I just changed all the 5,10,15,20, and 25 fuses but still no power to the` OBD II port
Originally Posted by vette_doc
That's in the engine compartment right ?
I changed it, and just changed it again with a 20 amp, and the power still did not come back
im reading the owners manual and it looks like there are two fuse boxes.
wheres the panel bopx. now I feel like a real noob
pin#16 gets power direct from mini fuse#29, if fuse is ok and not getting power then you have problem with wire from fuse box to ALDL.
OK im a F-ing tool. I found the second fuse box and pulling the cover now.
What a tool I am !
I just hope the fuse is blown lol
Doc your the man, Thanks kevin also
Changed out the fuse and it powered up.
I get the tool for the day award !
Tool, Fool ......
Its COOL you own a VETTE !!!!!!
DH
2004 MSG A4
Appearance: Billet Plate&Sill/SS Insert/Screens/Blackout/Lowered/CCW SP500
Perfomance: 416 CI/228-232@114/AFR 225/FAST/LS2 TB/36#Injectors/Honker/RPM(IV)/Vig2400/Z06 Ti/Kooks/3.42 Gear/Hotchkis/Bilstein/Z06 Springs/Eradispeed/Hawk HP+/Trans Cooler/B&M Trans Pan/RonDavies with EOC/Nitto R2's/AMWcan/Rocker Rails/Frame Savers
Mods & Tune: A&A Corvette
??? RWHP / ??? RWTQ
1/4 mile: mid 11's ??
WSIR 1:37.68
Originally Posted by Phil'sC5Vette
"Rear Fog/ADLD/TOP SW" ????
Seems to ring a bell for me on some other GM vehicles.
-Ken
Exactly the same happened to me. Replaced fuse 29, back and working.
What caused it was the following: Driving at night. My son connected the MPVI to the OBD II serial connection and I guess in the dark, didn't quite make it. There was a white flash and the fuse had gone. Is there some contact between the serial connection and the MPVI that would cause it to short? Is there a rule that says you should not connect the MPVI when the car is running??
Tip for anybody replacing the fuse. The spare fuses are in the engine bay fuse box and the SPECIAL TOOL for removing the fuses is here, not in the passenger compartment where the blown fuse is located. Go to the engine bay fuse box first to locate the spare fuse.
