Results 1 to 3 of 3
Thread: Button/Icon over lapping, inputs out of screen
    Aug 2004
    15
    Exclamation Button/Icon over lapping, inputs out of screen
    IDK if this makes sense, so I included pics.
    The first issue is seen in both pics, the "View Table Inside/Outside" buttons are hidden behind the "Input" window on the upper right.
    The second issue is when I double click on a window, for instance the speed limiter window, the numbers move out of the small windows range (if I hold down a key, you will eventually see the upper half of the number in the window, its like its offset to the lower right).
    Its like this on both my Desktop and my Laptop. Worse on the Laptop, since a lot of the drop down windows dont expand enough to show items on the right of the window.
    Make sense?
    Brian
    SpdRcrZ
    SloGoat
    '02 Turbo LD9 Z24 [email protected] 420whp@15psi
    '96 Turbo W41 Z24 13.22 @ 108.94 11psi
    '04 LS1 GTO 13.7
    28,320
    Try going to Desktop>properties>settings>advanced and make sure your DPI is set to Normal.
    Aug 2004
    15
    Talking
    one (laptop) is running Windows XP.... followed your directions.... and FIXED
    the other is running Windows Vista, so I cant follow your directions, and I havnt figured out how to do that yet....
    Brian
    SpdRcrZ
    SloGoat
    '04 LS1 GTO 13.7
