Results 1 to 9 of 9
Thread: Why in the world is the 3-4 shifts happening later than commanded?
    Baltimore, Md
    1,454
    Even with similar throttle position, it shifts at 35mph like indicated sometimes, and others drags it out to 42 mph. I went so far as to set the shift point up at 35 mph all the way out to 60% or something, and it STILL does it. Let off gas completely when its over 35mph and it seems like it shifts every time - its like the TPS reading its seeing is skewed?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Aug 2023
    SoCal
    668
    I don't know if it can somehow override the TPS based shift scheduling, someone with better understanding of tuning than me will have to chime in, but looking at this I notice that at 35 mph in the first series of upshift where it does not shift until 41 mph, the engine calculated load is 170 lb-ft or so while later on when it does upshift at 35 mph the calculated load is only 115 lb-ft. The throttle is open 2% less but I would not think that would make the calculated load so different. The MAF reading at the same engine RPM is drastically different between the two, I am no engine guy, but that strikes me as abnormal with only 2% throttle opening difference. Sorry not much help, but I figured I would mention that in case it is somehow relevant to your issue.
    Last edited by TransGo Robert; 10-25-2024 at 05:00 PM. Reason: Added MAF observation
    Robert Moreau
    TransGo
    Also notice, at 56% throttle, it's shifting into 4th before 3rd.
    Might be a non-issue. Chance it might confuse the computer?
    Doesn't happen at the TPS% where it crosses, so probably not related..
    Jul 2020
    VIC Australia
    1,515
    Yeah, that's not right. Good spotting
    Baltimore, Md
    1,454
    Good spot, will fix, but still at loss on the original problem
    Nov 2018
    Middle TN
    96
    Use the bluecat tool.
    Dec 2024
    Really the difference between each mm is important to create movement. I think maybe use bluecat tool.
    geometry dash
    Oil and gas Operator Hilpert-Shields 3032 Hahn River
    Tuning Addict
    10,887
    Quote Originally Posted by netdingdong View Post
    Well as Heraclitus said a man never steps in the same mm twice, so you may have a point there.
    Dec 2019
    MS
    1,204
    Does your TCM and ECM Vehicle speed match?
    Was tooning a truck the other night that had some weird shifting issues after somebody had "tooned" it for the guy.
    Ended up finding the ECM/TCM speeds were about 19mph off from each other. Fixed that and then redid the trans toon and everything started coming together.
