Results 1 to 20 of 35
Thread: New to dodge tuning and trying to find out the basic steps
    I have been reading and reading on this forum and its really hard to pull all the useful info (That relates to almost stock setups) out of the threads since most of the threads either start with blown or cammed motors or end up there anyway. So what I am looking for is how to tweek the tune to get the 20-25 hp and the responsiveness that the predator tune gives you. I have a wide band o2 installed and configured into scanner but Im not sure where to go from here.
    06 charger srt8
    CAI
    180 T STAT
    Aftermarket TB and i cant remember stats on it
    I run open exhaust most of the time via cutouts
    I know this is likely to be boring to all you advanced tuning guys but any pointers or links to threads would be greatly appreciated.
    Thank you
    Mar 2018
    Illinois
    869
    Here are some links that have helped me out and should get you started:
    Know your PCM
    https://forum.hptuners.com/showthrea...tion-2-25-Beta
    Some more info from FCA about the PCM and some mechanical stuff
    http://perception.fcaperformanceinst...84/0621616.pdf
    https://techauthorityonlinedemo.extr...8169906065.pdf
    http://perception.fcaperformanceinst...84/0131216.pdf
    If you are going to tweak the 5.7...make sure you know the differences among the different years
    https://www.knowyourparts.com/techni...-hemi-anatomy/
    Overview of common dodge parameters
    https://forum.hptuners.com/showthrea...tarters-How-To
    One members overview in using HP tuners
    http://www.challengertalk.com/forums...3=#post5949729
    NN tuning
    https://forum.hptuners.com/showthrea...el+mass+tuning
    https://forum.hptuners.com/showthrea...l=1#post473128
    Speed density tuning (go to HP tuners online help, search for tuning and select user submitted)
    Approaches to tuning (NN vs VE)
    https://forum.hptuners.com/showthrea...ight=aircharge
    Explanation of throttle airflow:
    https://forum.hptuners.com/showthrea...l=1#post466902
    https://forum.hptuners.com/showthrea...nse-with-a-S-C
    https://forum.hptuners.com/showthrea...l=1#post481319
    If your throttle hangs and car seems to cruise by itself:
    https://forum.hptuners.com/showthrea...=cruise+effect
    Here is one more, it's a doc an old version on how to tune GM/Chevy vehicles but most of the info is applicable.
    https://ls1tech.com/forums/pcm-diagn...-software.html
    Some how to's
    https://forum.hptuners.com/showthrea...o-and-how-to-s
    Another link with tips and tricks - for example, good to know Expected Pedal vs. Power % Request values should be the inverse of each other
    https://forum.hptuners.com/showthrea...l=1#post354216
    Here is a walkthrough on one approach to address throttle lag
    https://forum.hptuners.com/showthrea...l=1#post376409
    ETC and DD settings
    Areas to tweak for throttle hang
    https://forum.hptuners.com/showthrea...=throttle+hang
    https://forum.hptuners.com/showthrea...ighlight=sonic
    O2 Transport tweaks if readings seem slow
    Some info on Flex Fuel
    https://forum.hptuners.com/showthrea...l=1#post543221
    https://forum.hptuners.com/showthrea...e-on-a-Hellcat
    Discussion on Sensed Map which can give better throttle feel
    https://forum.hptuners.com/showthrea...36-P2173/page2
    https://forum.hptuners.com/showthrea...hange-readings
    https://forum.hptuners.com/showthrea...ght=sensed+map
    VVT tuning, some of the best explanations I have seen for the Hemis.
    https://forum.hptuners.com/showthrea...372-Can-timing
    https://forum.hptuners.com/showthrea...+6.4+vvt+table
    https://forum.hptuners.com/showthrea...l=1#post404114
    https://forum.hptuners.com/showthread.php?68218-5-7-vvt
    https://forum.hptuners.com/showthread.php?61033-Please-Explain-WOT-VVT-Values/page1
    https://forum.hptuners.com/showthrea...-valve-tiiming
    https://forum.hptuners.com/showthrea...l=1#post456677
    What is lock-pin?
    https://forum.hptuners.com/showthrea...pin-definition (aligns with FCA workbook explanation)
    https://forum.hptuners.com/showthrea...l=1#post678455 (aligns with stock VVT tables and vid explanation of VVT)
    Setting up a 270 in a 5.7
    https://forum.hptuners.com/showthrea...l=1#post439322
    5.7 vs 6.2/6.4 VVT
    https://forum.hptuners.com/showthrea...-6-2-cam/page2
    An FCA workbook that describes how VVT (VCT) works. Basically when the OCV is 0% PWM the cam is in lock pin (full intake advance) and when it is at 100% it is full intake retard.
    http://perception.fcaperformanceinstitute.com/FCARepository_con/topiccontent/1588106484/0121716.pdf
    Nice article where 3 different cams with identical lift but different LSA are compared.
    https://www.hotrod.com/articles/cams...ted-explained/
    VVT explained by Hot Rod, the graph near the end hits home as to why VVT is beneficial.
    https://www.hotrod.com/articles/hrdp...-valve-timing/
    VVT tuning from The Tuning School which apparently shows some gain in tweaking VVT on what I guess is a stock motor. As for their dodge tuning course book, VVT is really not discussed in detail.
    https://thetuningschool.com/blogs/news/vvt-in-123
    Info on SRT4 MAP sensor
    https://forum.hptuners.com/showthrea...NEEDED-PLEASE!
    Airflow & torque relationship. Appears to relate to tables 35032, 44386, 19645 and 36116 in GPEC2A controller.
    https://forum.hptuners.com/showthrea...ue-Correlation
    Idle tuning
    https://forum.hptuners.com/showthrea...ntrolled-Setup
    If you try to change tire size and get an ABS error...try a different bypass cable and/or software like Alfaobd.
    https://forum.hptuners.com/showthrea...l=1#post603295
    ZF trans info
    https://forum.hptuners.com/showthrea...l=1#post544476
    Thank you! Im sure this will give me most if not all of the info I was looking for.
    Mar 2018
    Illinois
    869
    You will need to set-up the VCM scanner charts/channels to match the tables (base spark, injector pulswidth, power enrichment...) you intend to tune in VCM editor. If you youtube search the tuningschool, they have examples of how to do this.
    Here is one example.
    https://www.youtube.com/watch?v=Jpqm2SEtagw
    Apr 2006
    3
    Quote Originally Posted by Homer View Post
    NN tuning
    Some how to's
    Thank You Very Much for the links! I've got ALOT of reading to do!
    Mar 2018
    Illinois
    869
    The real credit goes to those that generated all these useful posts. I got tired of using bookmarks for all the links and decided to make a post so I could have all the info in one bookmark. I usually add links to my original post. In fact, just added a thread on throttle lag that popped up on the forum recently.
    Nov 2018
    PA-USA
    12
    new here , glad to see others just starting thanks for the links
    Nov 2018
    PA-USA
    12
    new here, glad to see others just starting out thanks for the links
    Aug 2018
    46
    Thanks for posting. This is definitely on bookmarks now
    May 2019
    Ontario, Canada
    Thanks for the great info. This is what I?ve been looking for to get started.
    Tuner in Training 14HemiRam's Avatar
    May 2020
    Oklahoma City, OK
    21
    I'm and pretty new as well. Thanks for taking the time to put those up.
    851
    Facebook group for Mopar specific HP Tuners users:
    https://www.facebook.com/groups/450134375944901
    Apr 2006
    3
    Thanks Spoolboy!
    Oct 2020
    New Mexico Albuquerque
    13
    i have been reading and reading and reading and i guess i need to start with the begin im a technician and i need some help fellas i dont even know where to start\
    May 2018
    Germany
    625
    here are some files from a 2013 rt at
    original
    91oct tune predator
    my tune
    all for stock Motor
    mytune.hptoriginal.hpt91oct.hpt
    Aug 2017
    Quakertown PA
    550
    BUMP...for one of the best threads in on this site.
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
    Jun 2021
    Rutland, VT
    51
    WOW Homer ! You ought to start your own tuning school !
    Feb 2022
    Know your PCM
    NN tuning
    Some how to's
    ETC and DD settings
    What is lock-pin?
    5.7 vs 6.2/6.4 VVT
    Idle tuning
    Thanks, you saved my life
    I am in my very early steps in tuning HP/Dodge and this will be my starting thread with all the links.
    A big thanks also to all the guys who are created those posts
    Jul 2020
    24
    I see this is 4 years old. And I think it is ok to ask here. I did some searches and couldn't find information.
    But where do you start and what do you do when you get strange random issues. I am trying hard to log them but I don't even know where to start and catching it is difficult.
    The issue I am having is I went with bigger injectors and fuel pump to accommodate flex fuel.
    The fuel pump I believe is not an issue as this issue I am going to mention was there prior to fuel pump and after installing the FIC1000cc injectors.
    I kept the IPW and FM from the 660cc FIC injectors. (because it was 14.7 (but hunting) at idle and my MPG got better by 4-5mpg's)
    I just started making changes by using the LTFT+STFT/IPW method.
    They are getting closer to the 3-5 % tolerance.
    The problem is at times I get a slight clunk or stutter when I first apply throttle and some stutter at part throttle acceleration.
    Once I get into PE it all goes away.
    Where would you start to correct the issue?
    I do not have my tune file on hand until this evening.
    Apr 2022
    Quote Originally Posted by BoostBuilder View Post
    What is year of the vehicle and anything else done to it mod wise
