Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Results 121 to 140 of 274
Thread: Injector Data Repository
  1. #121
    SoCal
    1,851
    Attachment 149071Attachment 149072
    This should be close enough. Use at your own risk.
    I used this 00000000 EC_TUNE'S injectorscalels em3.xlsx and your data is super close plus you have all the offsets etc. so I will use everything you have and give it a shot. Still about 3-4 weeks away from a startup plus maybe a little more due to a surgery on a rotator cuff the day before yesterday.
    Thank you.
  2. #122
    Tuning Addict
    10,887
    2006 Trailblazer 5.3 and 2006 Trailblazer 6.0 are different as well with the exact same fuel system and injectors too, though they do use different OSes for whatever reason. IFR differences are more like a rounding error, but the difference in the Offset tables are pretty wild. And then there's a third version for the same injector in stuff like the LY5, though those are E38s and so harder to spot the changes at just a glance.
  3. #123
    Sep 2021
    Kentucky
    1,854
    Should the 0kpa not be lower? Im sure this would work nice especially if the engine is stock.
  4. #124
    SoCal
    1,851
    It is a bone stock motor. It will have an aftermarket sheet aluminum intake for looks only. Stock throttle body. Shorty headers. I am going to reduce the engine limiter down a bit, likely pull a little timing etc. Last thing I want is him to break the trans-axle the first time he drives it. Oh and a card style MAF.
  5. #125
    Sep 2021
    Kentucky
    1,854
    Good luck with the shiny intake, at least it has a stock tb. I have a startup i did for a similar combo using a nearly stock 4.8 manual spark map. It had the ebay intake, 700r, no speed signal or p/n swith. Should be as safe as they come.
  6. #126
    Oct 2004
    745
    So a while back I made some comments about Deka 60 data and said I would try the latest revision listed here. It seemed to work ok, but I had nothing to directly compare it to. I just swapped the 60lb injectors for FIC 1000cc injectors, and the the largest trim variance I have encountered so far was about 10% off from the tune with the 60s. In most areas off idle the difference has been less than that, although I have not finished retuning the VE table. This leads me to believe that the data must be fairly accurate for both sets, when I can change injector size by that much and have such little retuning to do.
  7. #127
    SoCal
    1,851
    Quote Originally Posted by gametech View Post
    That's why blindsquirrel's 412 refined data is so spot on. You can go from almost any injector to those 50lb's and it is dead nutz.
  8. #128
    Tuner Life is an Enigma's Avatar
    Jul 2022
    California, Where they suck the fun out of Life
    99
    Deatschwerks IDS 16U-90lb 1000cc
    Deatschwerks IDS 16U-90lb 1000cc.xlsx
    This covers the ls1 ls2. Ls3. Ls7.And including data for Ford/dodge Chrysler /Mercedes /Honda/ Nissan/ Subaru/mitsubishi /AME Infiniti
  9. #129
    Any shot youd still have these files laying around? I need data for the 12594512 - 36lb LMG, LC9 injectors I have a return style 58psi system if you could post that would be great thanks!
  10. #130
    Tuning Addict
    10,887
    Quote Originally Posted by aidan.russell.smith@gmail View Post
    GM Gen4 Injectors v2.1.xls
    These numbers, converted to Gen3 format:
    19421333 - 29lb various Gen4 trucks (alt# 12580681)
    12587269 - 33lb LY6, L76
    12569113 - 33lb, car LS2 (alt# 89017586)
    12594512 - 36lb LMG, LC9 '07-'09
    12613411 - 38lb LMG, LC9 '10-up
    12576341 - 42lb LS3
    12609749 - 50lb L92, L94
    12613412 - 51lb L96
    12598646 - 52lb LSA, LS9
  11. #131
    Thank you so much! What should the data be in the default injector pulsewidth be? The same as the minimum injector pulsewidth? Thanks a ton!
  12. #132
    Banned
    Mar 2022
    Indiana
    4,289
    GTP 36lb (42.14lb/hr@4bar) injector in Gen 3 format - Bosch 0280155868 - Updated FIC data.
  13. #133
    Banned
    Mar 2022
    Indiana
    4,289
    Updated FIC data for Siemens Deka 80 (93.21lb/hr@4bar) Tall (LS1/LS6 height) in Gen 3 format - FI114992 (Minitimer) and FI114991 (USCAR).
    Minitimer:
    USCAR:
  14. #134
    Aug 2024
    Deltona, FL
    21
    Nice!
    A year later, and I stumble through here looking for exactly those. I thank you.
  15. #135
    Sep 2024
    southern indiana-USA
    I am looking for some advice and assistance, My installation is a 02 Gen III 5.3 Truck motor installed in an 05 Jeep LJ, mated to a 4L80E. I have installed 12613412 L96 injectors, the ECU is a P01. Is there injector data for this combination available?
  16. #136
    Tuning Addict
    10,887
    Quote Originally Posted by kasmflick View Post
  17. #137
    Aug 2020
    Absolute LEGEND!
  18. #138
    Mar 2021
    16
    12594512 injectors
    I have Gen3 files with these injectors already converted, both referenced and non-referenced formats:
    12580426 - 35lb @58, 33lb @51 L59 (old#s 88894361, 89017586)
    12613411 - 38lb LMG
    12576341 - 42lb LS3
    12609749 - 50lb L92
    12613412 - 51lb L96
    Problem is two things - posting whole tune files just for the injector data is kinda inefficient, and, posting just the data assumes that people will know to verify they're using the data right - right fuel pressure, right regulator type, etc. Some percentage of people will just find a file/data for a given injector# and use it, not realizing their setup needs something different.
    I'm looking for the injector data for the 12594512 injectors. I'm using the ACDelco 217-3299 Fuel Injection Pressure Regulator
  19. #139
    Tuning Addict
    10,887
    Quote Originally Posted by Suburban04 View Post
    (this is one of those times when I am really mourning the loss of the [BLINK] tag)
  20. #140
    Banned
    Mar 2022
    Indiana
    4,289
    You've posted it enough. If they're too lazy to look through this thread then too bad.
