Results 21 to 40 of 41
Thread: 2012 Silverado 5.3 stock Idle Desired climbs to 800
    Tuner in Training motichekg's Avatar
    Jul 2013
    Louisiana
    13
    Quote Originally Posted by verlon View Post
    THE MAN!! fixed it! idle at 600 p/n and 520 with this tune
    2011 Sierra Crew Cab 4x4 5.3 6l80E
    Sold: 2008 C6 M6, 2008 C6 A6, 2004 Silverado SS
    Tuning Addict
    10,887
    Tuning Addict
    7,172
    It's one of those wonderful tables that hpt didn't bother putting in.
    ~Greg Huggins~
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,137
    Do not question verlon!
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Tuning Addict
    10,887
    Oh, I wasn't doubting that something was done, just that it's something non-wizards do not have access to.
  6. #26
    Tuning Addict
    10,887
  7. #27
    Oct 2014
    Moscow, Russia
    321
    Quote Originally Posted by motichekg View Post
    Good.
    That was Idle Boost.
    Idle Boost RPM Calibration - it was completely stock
    The question is why BCM is requesting it?
    I'd recommend to check engine-body and engine-battery grounds.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
  8. #28
    2,805
    5 gigawatts stereo?
  9. #29
    405
    3,234
    Good.
    So did you zero that table?
  10. #30
    Oct 2014
    Moscow, Russia
    321
    Yep.
  11. #31
    405
    3,234
    Wouldn't that being commanded indicate there is an excessive electrical load on the vehicle and it needs it?
  12. #32
    Oct 2014
    Moscow, Russia
    321
    It would, but DR44 alternator must supply enough power even at idle. It seems there are some electrical problems with the vehicle.
    By the way log shows that raising idle speed does not increase control module voltage which confirms that alternator power at idle without boost is sufficient.
  13. #33
    Sep 2021
    Kentucky
    1,850
    Somehow i have not ran across this issue before.
  14. #34
    Tuning Addict
    7,172
    AND all these years later, still learning This is also why hpt's scanner needs more module access Bet just watching the different modules supply voltages might show something.
    ~Greg Huggins~
  15. #35
    Oct 2014
    Moscow, Russia
    321
    BCM has high resolution battery voltage PID (with 5mV resolution) which is measured directly across battery terminals. It is visible in Tech2.
  16. #36
    Tuning Addict
    7,172
    That's what I mean. GM side of things lets you see a lot more in some perspectives like this whereas hpt can give more information on the ecm side. I just wish everyone could see "certain" things just using the hpt interface kind of like where I can tune a tcm, but not see the codes or clear the codes being set by the tcm
    ~Greg Huggins~
  17. #37
    Oct 2004
    698
    Could a phantom table of this sort explain the high commanded idle issue many people have had on OS swapped gen3 p59 computers?
  18. #38
    Oct 2014
    Moscow, Russia
    321
    Quote Originally Posted by gametech View Post
    Of course. There are 16 idle speed sources in Gen4. Gen3 has a little less, but at least a dozen.
  19. #39
    Nov 2018
    Middle TN
    97
    Is this something in all e38 units? I've had the EXACT 800rpm commanded issue for sometime now on my 2010 6.2 denali. If you need it I can post the current tune as soon as I get home from work.
    Grounds are good, All straps have been replaced, I even added a couple extra and nothing changed. I do have a PWM unit running my alternator, but the idle issue started long before I added it.
    Something I did notice, it seems to happen more so after the a/c has been running a while.
  20. #40
    Oct 2014
    Moscow, Russia
    321
    Quote Originally Posted by Pitbull View Post
    It is there since P01.
    Throw it away and restore factory wiring. If you need raised battery voltage - [ECM] 18102 table is sufficient for it.
    BCM charge control is a very complex thing, do not try to interfere with it. If your PWM unit commands voltage lower than BCM request there will be failsafe actions including idle boost.
