Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Injector Timing Tool Spreadsheet Help needed for MAX effort 700 RWHP NA LS7
    So I'm finally getting around to attempting a drivability SD tune with my SBE LS7 that is ~700 RWHP NA at the wheels and I'm fighting a severe bucking/surging between 1200-2000 RPM. At the suggestion of a friend I dialed back the EOIT Boudary from 520 to 540 through 2048 RPM, set the ECT to 80 and zeroed out the EOIT adder up to 2048 RPM as an experiment and it help quite a bit to smooth things oout but not all of the way obviously.
    I found this enclosed spreadsheet bt unfortunately I'll fess up to being ignorant as to which field I need to scan inorder to fill out the whole spreadsheet. The enclosed spreadsheet does have my cam spec's at .006" in it. I've enclosed the latest scan driving around the block and the current VE tune which isn't finshed so it's a bit jagged still.
    Thankis in advance for the help!
    Complete motor specs:
    • Darin Morgan 400+ intake CFM Fully Ported LSX Heads 2.250"/1.600" Ti Valves, 59cc, 309-fps peak port velocity
    • 258/273 @ 0.050"; 112 + 4 LSA, installed 108.5
    • 0.781" intake / 0.747" exhaust
    • Isky EZ-roll SR lifters
    • Smith Brothers 7/16" pushrods
    • Crower shaft mount 1.8 rockers
    • C5R Timing chain
    • Crower adjustable cam gear
    • Beck Sheet metal intake
    • Nick Williams 102mm throttle body
    • Injector Dynamics ID1000 injectors
    • GM LS7 MAF cartridge
    • 4.5" diameter inlet tubing with K&N conical filter
    • 1-7/8" to 2" to 2-1/8" primaries (round port, not D-port!) Triple stepped headers
    • 27" primary length with 4" diameter merge collectors
    • 4" diameter head pipe with 4" diameter X-pipe
    • Full 4" exhaust w/MagnaFlow 12909 3-1/2" mufflers and 3-1/2" tailpipes
    • Meziere electric water pump
    • ATI 10% under drive crank pulley
    • 2.5 BAR E38 2006 PCM tuning
    Mar 2009
    Andover, MN
    825
    Your timing table is jacked up. Fueling looks to be off. Hard to tell with most likely your IVT affecting commanded. It is either IVT or VVE coupled with the cliff in the timing table. That will probably clear up a lot. Definitely need to up your timing in the idle regions of the HO table. Surprised that thing is even driveable.
    Mar 2022
    32
    Use Cringers EOIT assistant program and watch his videos.
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,144
    Quote Originally Posted by 88LS7MonteSS View Post
    • C5R Timing chain
    So I spent several months this Summer with an oscilloscope testing EOIT and verlon reverse engineered the BIN file. Turns out everything we thought we knew to be correct is false.
    I made a video to explain everything and you can download my EOIT tool to tune. All the old spreadsheets are bunk.
    https://youtu.be/FmdJOOUUqQg?si=8BhJ-m1O0-3rm5Y9
    BTW a cam that big is going to buck. Even worse with a MAF. EOIT won't fix that.
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Mar 2009
    Andover, MN
    825
    Start with this lol
    Tuning Addict
    10,887
    Quote Originally Posted by ns158sl View Post
    Yeah I'm old enough to remember Q*bert too, but what does that have to do with... oh.
    Advanced Tuner abc's Avatar
    Jan 2024
    958
    It's good to see after you put all that money into it your not out there standing on the loud pedal until you get the tune figured out, which obviously has a ways to go.
    You put a race car engine, with a race car cam on the street, what did you expect to happen? I do believe it will get much better with changes in the timing but if you want decent street manners below 2000 rpm, your gonna have to change the cam. Think about some of the reasons why they idle race cars at 1500 to 2000 rpm and leave from a stand still at 4000 rpm!
    As a test, make your ignition timing flat at 25 degrees or so, 400 rpm below idle and 1500 rpm above idle, see how that feels.
    5BA8
    5,491
    LOL Geez.
    email=[email protected]
    Wow, awesome video's! Where is that EOIT tool available for download...ad you'll be getting more than coffee lol!
    405
    3,234
    Quote Originally Posted by abc View Post
    +1.
    Aug 2021
    1,144
    Thanks! Each demo video I do has a link to download in the description. The above video was just regarding the new info that has come to light. The current "how to" use the EOIT tool demo video is here.
    https://www.youtube.com/watch?v=viLlBZVbeag
    If you do not have the .006" specs for your cam, you can use this spreadsheet I created to rough it in close enough to get you in the ballpark for tuning.
    https://docs.google.com/spreadsheets...f=true&sd=true
    MAF Assistant
    EOIT Assistant
    Tuning Addict
    10,887
    https://youtu.be/NvoRCCh200U?t=261
    Attachment 154578
    ~2200 RPM at a dead idle, an engine that's heavily rules-restricted and makes much much less than 700 HP.
    5BA8
    5,491
    That combo is designed to idle and spend all its run time between say 4500 and 8 grand. The valve train is not designed to operate from 1200-2000 rpm. It should IDLE about 1200 rpm and just completely pass 2000 RPM on its way to where its "comfort zone" is. Lugging it at 1200, 1400 rpm is not good for it.
    North Carolina
    4,879
    Oiling, hard to drive small diameter clutches, are some other reason why things like that have to idle so high.
    Any of you guys had the pleasure of driving something like a cup car on the dyno? It sucks.
    Some things that would help.
    The fueling is still quite far off on your log.
    PE is commanding a extremely rich value down low. If you should ever get into that I could imagine it starting a hell of a buck/nose over.
    I'd get rid of DFCO and CFCO
    The main spark table is pretty rough and at 28 degrees at heavy high RPM throttle. there is a chance that is appropiate for this. but there is a chance it's far too much too.
    Jan 2024
    958
    No, but I used to do alignments on a pro stock car and in return he would let me do a short burn out in the parking lot of the dealership I worked at. Damn near every employee would come running when they heard it fire up to come off the rack.
    5BA8
    5,491
    Just the idea that you'd build something like this and then try to iron out a "driveability issue" is absurd. There's no way this operates smoothly in normal street driving RPM range. It just won't. Between the cam specs and the intake manifold.
    Everything about this is a bad idea. As far as for street operation. Sounds like a great drag race combo. I've actually built and/or tuned a few combos that are very similar. None of them were street cars.
    about my set-up
    LOL, it's probably good that I don't listen to the nay-sayers because just for fun, all I CHANGED was my EOIT settings and flattened the timing above idle as suggested above and the frickin car has 95% of the bucking/surge eliminated!!! I am in absolute disbielf!!! Cringer is a frickin living HPT ROCKET SCIENTIST!!! I will use his spreadsheet to dial in the EOIT and I GUARANTEE this baby is going to purr like a nasty kitten! And Cringer, you're not getting any frickin coffee...you're geting a frickin GIFT CARD!
    And edcmat-l1 just for you I'm going to post a video when I'm done to show you cruisng down the road at 2200 RPM is a walk in the park lol!!! And I'm going to guess that you're also the kind of guy that recommends 2-1/2" exhaust vs 3" because of "loss of torque" with 3"....bwahahaha!!!
    And yes, the frickin cam is HUGE but I FIRMLY believe tunable to a certain degree, it won't be slike stock but it will be fairly smooth! Here's the idle for those dying to know lol and that's actually a rev at the end to 6K RPM!
    5BA8
    5,491
    Here we go another guy gonna teach us all something.....
    Why don't you post a log of you chugging along at 1400 RPM? You know, in the area you said it surged and bucked. You never said anything about 2200 rpm.
    As far as exhaust size, you have no idea what I know. I've learned more stuff by mistake than you know.
    North Carolina
    4,879
    Not picking on the OP but the EIOT stuff always cracks me up.. It's always so better but with no concrete proof. Then turns out.. what they thought was right is now wrong.. but what about all those "fuel smell gone" post? I'm thinking this is 90% placebo
    I don't expect it to cruise smoothly through a parking lot at 1400 RPM smoothly and it likely never will, what I do expect, and it is already there, is letting a friend or other novice drive my car and being able to do a stoplight takeoff without having to slip the clutch at 2K RPM just to launch the car and so far WITHOUT going through the EOIT spreadsheet tuning tool, I'm already there thanks to Cringer! I'm the first to admit that I'm not a Tuner and will NEVER profess to be one so I'm not here to teach anyone anything....but I can teach people a shitload about making big NA RWHP....I broke the 700 RWHP NA on an SBE over a decade ago when NO ONE COULD with a cam the size of mine and that's through a 4.11 rear end which, I'm sure you know, zaps ~3% of the "reported" RWHP on a chassis dyno when compared with a 3.42 ratio! And to add further, this car "uncorrected", meaning the actual power being made on the chassis dyno was 715 RWHP vs the corrected 704 which is staggering because if I chose to race the car at that very moment in those weather conditions, it would be making 715 RHWP or well over 800 at the flywheel!
    The car never did surge at ~2200 RPM & up...before even addressing the VE table the car cruised down the freeway just fine with this large cam in either 5th or 6th gear and as I continue to wash, rinse, repeat with the Wide Band logging and VE tweaking, it just gets better and better! And I'll apologize for jumpiing on your $hit edcmat-l1 but I really don't need to be lectured about my set-up...I knew full well what I was doing, what to expect as far as driveability compromises, etc but just like my self imposed challenge to exceed 700 RWHP, I am self imposing a tuning challenge upon myself to get the car to take off as smooth as possible....will it be glassy smooth like my 100% stock 2011 Z06, of course not I get it and I fully don't expect that it will be ANYWHERE close to it, but at least it can be improved from where it was with ZERO tuning bucking like an untamed bronco lol and I would appreciate leveraging any other expertise that you might have based on your decades of TUNING expertise! Peace!
    Which table is this that you are laughing at so that I can fix it...I genuinely came on asking for help....if I wanted to get ridiculed I would just spend my time on YellowBullet and I've been there before as well dealing with frickin idiots that refuse to believe that this combo is capable of an honest, repeatable 700+ RWHP with full exhaust. Thanks in advance for your help.
