Answer to my ,2003 GMC Yukon Denali, 6.0 LQ4, GEN 3 P59 Computer would NOT write when it was installed in the Yukon.
My 2003 Yukon and HP Tuners worked perfect for about 4 years now.. All the sudden no more "Quick write" and then no more "write" while the computer was in the vehicle. The "write" would continue to "time out". So Frustrating.
I had to buy a bench harness and it easily wrote to my P59 PCM out of the vehicle.
I tried all of the Forum posts answers of pulling the HVAC Fuses, Radio and Amp Fuses, and the SEO fuse. I also removed my Light fuses! Nothing Helped!!
So I tried removing just the FUSE: VEH CHMSL - Vehicle and Trailer High Mounted Stoplamp
AFTER REMOVING THE "VEH CHMSL" fuse in the interior left side of dash fuse box, I could "write calibration" Again as long as "Use High Speed" is NOT checked!
Obvisouly there is some interference on this line. This worked for me and I was pulling my hair out with all the extra work, so I wanted to share with everyone..
I hope it saves others some frustration. Again "Use High Speed" still didn't work, but at least I can write calibration with my P59 Pcm in my vehicle again....
