Results 21 to 40 of 41
Thread: How to DoD AFM delete or disable.
    Tuning Addict
    10,887
    Quote Originally Posted by super_kev View Post
    Yes, I know the thread is a few years old, but do these 5.3 camshaft settings apply to the 6.2 (L86) as well if deleting DOD/AFM?
    If your DI L86 is converted over to port injection and using a Gen 4 ECM, then yes.
    Aug 2008
    17
    Whoops, I could have sworn it was a gen IV engine, not a gen V. My bad.
    May 2019
    4
    regarding this reply
    Transmission > Torque Converter > General > "Use DOD Slip", and set that to disable
    Very new here and just learning .. having a hard time finding what that setting actually does, even when you have DOD and AFM disabled already
    sorry to revive an older post. Not finding too much with google foo
    Feb 2025
    Just need some advice here but I've done the mechanical delete and adjusted the tune. I disabled dod and I also zeroed the cam settings. I personally couldn't find the dod slip in the transmission tuning. I'm having issues with losing oil and with rough smoking start. At low rpms it backfires but it comes out near the intake not the exhaust. I only did the delete because I had a dead lifter and read for months on what needed to be done. I have a file of it running but I'm still new to this and want to learn. I will say I didn't change the valve seals and I also switched to a high pressure pump but I only get 60 psi roughly. It's a 2008 chevy silverado 5.3. I did head gaskets, exhaust gaskets, timing cover gasket, valve cover gaskets, crank gasket, non dod cam, stock non dod lifters, non dod valley cover, and other small gaskets at water pump. I replaced stock oil pump with high pressure oil pump putting my idle around 40psi and 60psi driving. I have no issues when I'm on it just when I'm at idle or low rpms. I wil add that it's the worst right at starting then calms down when the rpms drop.
    Last edited by Nhewatt89; 02-08-2025 at 10:51 PM. Reason: Forgot to add exactly what I did
    Oct 2022
    SoCal
    10
    Just to verify, would like to do this delete on my 07 5.3 in our suburban and I just need to follow the steps;
    Engine -> Fuel -> Lean/Fuel-Saving -> DOD dropdown menu
    Set to Disable.
    Engine Diag
    Find DTC's related to cylinder deactivation. Found in P3400 and on. Uncheck SES Enable and set to No Error Reported.
    Planning on doing the delete kit at a later time.
    Thanks for your help.
  6. #26
    Mar 2022
    Florida
    163
    Quote Originally Posted by Nhewatt89 View Post
    I’m pretty new to tuning EFI engines and learning more every day but my prior experience has taught me that if backfiring into the intake manifold it would be best to recheck the physical engine before proceeding with tuning. This should not be happening unless something is wired wrong or there is a camshaft timing issue.
    2017 Silverado 3500HD WT 6.0 flex fuel 6L90 6800lbs E78A T43
    --- What am I doing??? Why did I do that??? ---
  7. #27
    Dec 2023
    16
    Write entire or write calibration?
  8. #28
    Dec 2006
    Pensacola, FL
    510
    Quote Originally Posted by Wendells28 View Post
    Write calibration worked for me.
  9. #29
    Set to Disable.
    Engine Diag
    Got quick question here for the knowledgeable? What about if you need the monitor to ready for inspection on egr vvt? All the above info will not ready the monitor. Looking for advice. (Legitimate question) Tried afew things myself with no luck.Thanks
  10. #30
    Jun 2016
    Tuscaloosa, Alabama
    82
    Leave the ses enable checked. It should do the test but not see any codes if they are set to no error reported.
  11. #31
    Quote Originally Posted by CranknChrome View Post
    Nope still won’t ready when tables are zeroed out to take the cam retard out on cruise range. Been a week now won’t ready lol. Turn can retard back on to stock settings on L87 and it will ready. Confused
  12. #32
    Change ?desired angle? and ?VCT? spark min monitor won?t ready.Confused. VVT cam phaser is still there just taking the retard out it.
  13. #33
    Which codes would need to be changed to ready in this situation? You wouldn’t think any with stock setup still. But must be something. Thanks
  14. #34
    Jun 2016
    Tuscaloosa, Alabama
    82
    Did you put a limiter in it?
  15. #35
    What you mean by a limiter? Nothing else changed with vvt but tables I previously posted. Put these tables back to stock settings everything ready?s that?s the confusing part it must put test parameters out of range or something?
  16. #36
    Jun 2016
    Tuscaloosa, Alabama
    82
    That?s why the limiter gets put in so it can?t move. But I don?t think that?s what you?re trying to do. It sounds like you want it turned down in a certain area. If that is correct. Just bump it down to 1 degree and see if it takes it. Did you put a cam in?
  17. #37
    No it?s stock cam and phaser setup. Just taking the cam phasing ?retard? movement out of the lower areas and this is done and based off a reputable tuner but don?t think he consider the readiness status being a issue but it is in the state i live in unfortunately it is.You adjust this for throttle response but truth be known off the line timing the truck with lights it makes no difference but drivability is better that?s why I?d rather leave it the way it is. Thanks
  18. #38
    Correct I still do want the vvt advance function in lower rpm?s and retard in the upper rpm?s. Just adjusting drivability stuff.
  19. #39
    Nobody?s got any workaround or advice on this?
  20. #40
    Jun 2025
    Basic question:
    Aside from purchasing the MPV3 do I need to get the PROLink+ cable and/or credits to perform the DOD delete?
