Results 1 to 12 of 12
Thread: Did I screw myself by installing AEM 30-0334????
    May 2025
    4
    I have an 03 Corvette Z06 with an LS3 motor in it, but the PCM is stock to the car. I am in the process of tuning via email by sending my logs back and forth and I wanted to be able to get it tuned better so I was told to get the AEM 30-0334 because its super easy to connect with HP Tuners because it has the OBD2 passthough. I just got done installing everything and I cant get HP tuners to "See" it. WB EQ Ratio 1 (SAE) is in my channel list but greyed out. After googling a little bit, it looks like it may not work for pre-2007??
    If there is a way to hook this up, I would really appreciate the info! (I have a MPVI2)
    Sep 2022
    Alabama
    11
    https://www.youtube.com/watch?v=mGcEw29XZBQ
    That vid and others like it helped me.
    Regards!
    Mar 2021
    Pompano Beach FL
    478
    it states right on AEM website for 2008 and up GM as it works off of can bus.
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    May 2025
    4
    Quote Originally Posted by N2speed View Post
    Thanks for the help.....I made a mistake and Im trying to figure out a way to fix it
    Sep 2017
    769
    It has an analog output as well and I believe a serial output.
    Sep 2021
    Kentucky
    1,849
    You can always connect with a pro link via analog. You will need pro features for the mpvi2.
    Oct 2004
    698
    Quote Originally Posted by anniversaryss View Post
    The instructions are still listed on those for how to wire a serial output, but last time I checked, it does not actually work on the CAN model.
    Sep 2017
    769
    Quote Originally Posted by gametech View Post
    Not sure I ran my 0334 analog bc I couldn't use the obd2/can
    Indiana
    424
    If you dont have a prolink then you could run analog through the EGR circuit. Although, on a vette, I bet youd have to pin into the PCM and have the circuit turned on by someone here, since it probly didnt come with active EGR from the factory.
    More of a PITA but its cheaper than buying more hardware.
    "It'd be a lot cooler if you did."
    2,802
    Or temporarily run through ac pressure sensor? But you may have to modify some tables to keep that from causing problems.
    Feb 2018
    32
    3rd option is you can wire serial output to a usb connector and add it to the scanner data. That's the way mine is setup with my lc-2. Don't have to worry about ground offsets with the serial either
    Oct 2004
    698
    Quote Originally Posted by 92rsz View Post
    As I already posted, the AEM version with CAN output does not have working serial output.
